Do you loctite teh clutch hub and fan set to the engine (OS50/Knight 50)?
Loctite Engine nut?
yes
Adewww.accurc.com
adrian@accurc.com
This is an apple free zone
I use the rule that if your putting metal screws/nuts into metal threads use blue thread lock. I have never seen a crash because a screw 'did not' work loose !!
Use extra care with bearings, I add a little on a tooth pick into the tapped hole and screw the bolt in that has the bearing on it.
You don't want it working up into the ball race
