ive set all my twister 3d up but iam having problems with the tail my gyro is a airtrix a500-g the problem i seem to have is when in normal mode the and trimmed to hover every thing is fine altho i do seem to have to do quite a few corrections to the tail
when i switch to heading hold the tail becomes out of trim and i have to trim quite a bit of left in if i switch back trim it back to the right
anyone know if this is normal or do i need to set some thing up
i realy dont have a clue what im doing
also when in heading hold if i dont touch anything the rudder goes to full right and the servo buzzes as it pushes against the end if i start the main rotor this normaly stops do i need to set a end point for the gyro ive set it for channel 4 rudder but it doesnt seem to have much effect
i thought it was twitchy before
