Not getting enough thrust
  • Not getting enough thrust
    From the tail rotor of my Twister 3D - having (at last) got to the hover and flying stage I've run out of right rudder - the swash on the tail rotor is butted up to the gear box once the 3D is trimmed for sort of staright flight so I don't have any right turn - Is the pitch on the tail rotor adjustable relative to the swash - I've checked that its square to the main shaft.
    Incidentally thanks a million to all the experts out there (specially Ade) who take the time and trouble to get us newbies off the ground (and sometimes back there again ) safely.
    John
    your headspeed is probably too low. Its a pretty common problem with micros. You really need to get them humming to get those tiny tail blades working.
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
      Ade
      Ade do you have a recommended headspeed for he Twister 3D, usinf the standard wooden blades
      TDR (in progress)
      SAB Goblin 700
      Vibe 90SG Vibe 500E
      Kalt Baron30
        i really dont know what is a safe speed to run at with those woodies. I think the trex woods are rated for 2500?
        Ade
        www.accurc.com
        adrian@accurc.com
          Thanks Ade, I will check mine and see what the headspeed is,
          TDR (in progress)
          SAB Goblin 700
          Vibe 90SG Vibe 500E
          Kalt Baron30
            3D manual says head speeds "may approach 2000 rpm" so presumably it wouldn't recommend speeds above this
            John
              I found that they are happiest with a flat line throttle curve of 85%, so in normal mode you need the normal 0, 25, 50, 75, 100 and in idle up 1 you will need 85, 85, 85, 85, 85.
              Bring the throttle up to half stick and then engage idle up 1, you can then fly the model from there. You will most likely find the head speed is approaching 2100rpm and it will really hum. It will also smooth out the tail and make the tail seem much more powerful.
              Pete.
              Rise from the ashes with
