Oh god what have I done now.
  • Oh god what have I done now.
    Hey Guys
    It’s your Devon idiot hear. When I was fiddling with the helicopter last night trying to figure out the over heating problem I pulled a wire out from some where and have no idea whether it should be attached
    Ill try and describe it: the black wire coming out of the ESE there are two one thick and one coming off it very thin like the antenna wire. This wire is now attached to nothing .Where should it be connected to.
    Thanks for your help
    Infacto
    T-REX 450 SE HummingBird v2
    A Man can live about forty days without food, about three days without water, about eight minutes without air, but only for one second without hope"
    So one end of this thin black wire is still going into the ESC? if so, if you look at the lead from the ESC that plugs into your Rx, is the black lead missing?
    Some ESC with BEC have an on/off switch with a thin black and red cable going to the switch, has it pulled off that?
    Need a little more info on the ESC but sounds like it is Align off your 450XL? if it is not from the ESC to RX lead!!
    Fly today, tomorrow it may be too late !!
    http://www.ukheli.com for my T-Rex 600e / 600n build site
      http://www.rcheliaddict.co.uk/attach...1&d=1157530714
      Here is a pic of the wire.
        The photo is a little small, how long is the wire, it looks to be under a sleeve with the main battery neg (black) lead ?? Was this a new heli kit you built or 2nd hand ?
          its the small wire about 13cm long The hele was secound hand.
            Just maybe it was just left over wire that may have been used to run a Li-Po monitor / alarm, I can see the black/red/white going to the Rx, the other black lead looks like the areial, tape it up for a while and test all functions before flying.... (do you have a red wire coming out with the big red battery lead too?)
              Yes the red battery lead has one two .Its tucked up inside the sleave.
                Ok I will say it is left over from a Li-Po alarm for sure !!
                  Ok thanks.
