Twister 3D collective setup
  • Twister 3D collective setup
    Hi guys - I finally found a post on this forum remarking that the swash plate on the 3D moves down to increase pitch and thought this was due to a mistaken assembly in my new 3d. Can anyone tell me how to set up the radio for this - I have a Futaba 6X and its taken me 2 weeks, a burnt out servo, a scared cat and a few dings in blades and me just to get the cyclic settings right and my last try which involved reversing the throttle servo channel proved expensive. Needless to say I don't have any friendly folk to turn to - the heli- expert at the local model shop was as surpirised as I that swash going up to heaven produced negative pitch. I really wish there was just a few more hints in the instructions ....
    John
    you need to reverse the collective servo. How to do this is in the manual for the transmitter.
    Where are you?
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
      Not so easy
      In Aussie Land where model helos are in their infancy _ I was selling Graupner and Dieter helos in the UK in the 70s.
      The collective is controlled by 3 servos in 120 configuration so there isn't just one to reverse - I wondered if I had to reverse all 3
      John
        swash mix screen and change the collective pitch value from plus to minus.
        model helis arent in their infancy anywhere! check out rchelispot which is an international forum. might help you find somebody local to you.
        Ade
        www.accurc.com
        adrian@accurc.com
          for your help - I'll try that tonight - bit easier now that I know it's also known as the Eco 8 which explains lack of hits I had on search
          John
            Twister 3D needs the push rods all turing down about 5 turns.
            Swash 3 in the Transmitter and yes its right the Swash goes down for
            + Pitch. get all 3 to push the swash up or down then your getting there
            normal Tranny pitch curves are fine for hovering about.
            Mark
            www.uavaerialservices.co.uk
            BNUCs - Operations certified
            CAA - Permit for Aerial Work
              Is the Twister 3D the same as the ECO 8 and the ARK 400 ? - thinking of upgrade parts - ie better main shaft which seems very soft. There also seems a lack of info on the Twister 3D which makes me think its a recent badge engineered addition.
              John
                Ah no you cannot use Eco 8 parts and no idea about the Ark 400.
                You can go out and buy 6mm Carbon Rod and make your own main shafts
                it is a vast improvement. JP Perkins also do a metal swash plate which
                is worth having. The other bling for now i'd give a miss on.
                Mark
                  What makes you say give the upgrades a miss Disc (having just bought it but not yet fitted), apart form maybee it is expensive
                  TDR (in progress)
                  SAB Goblin 700
                  Vibe 90SG Vibe 500E
                  Kalt Baron30
                    weakest points on the Twister 3D are tail drive gear and servos. If you want
                    it fly and be stronger I'd recomend new servos on the CCPM stronger ones!
                    (the ones it comes with okay for circuits but any more you'll strip gears)
                    Carbon Main Shaft made with 6mm carbon you make these yourself.
                    (you'll also get a few out of one rod of carbon)
                    Metal Swash Plate - upgrade does make it smoother.
                    The other stuff will all help but i'd receomend the other stuff above 1st. Better servos are money well spent instead of the other goodies to begin with.
                    Mark
                      The answer (for now) - can not believe what a chore setting up the Futaba 6X Super has been - anyway for anyone else who is stuck in this situation here's what worked:
                      Servos - Front right (elevator) Ch2 / Back right (R cyclic) Ch6 / Back left (L cyclic) Ch 1
                      Radio setup: Reversed channels 1 & 2 / Swash plate 3 and SWSH settings Ch2 -30 / Ch1 -30 / Ch6 +30 - the values down from 50 till I get the hang of things
                      FWIW the thing came with a bent main shaft, a warped main gear with one fixing screw floating loose having been stripped out of its thread.
                      Sure have learned a lot along the way - might have been easier to buy a kit and build from scratch than rely on an 'Almost ready to fly' - JOKE
                      John
                        Ah well Perkins have said there not test flown! although the Box says they were. Warped gears are okay if runs well and doesnt rub or bind against
                        anything. Also the manual says seek help etc or have experience of CCPM.
                        But this is one reason of many we say go bigger heli wise because there
                        tougher and easier to fly.
                        Mark
                          Fair point Disc, I agree the tail drive is a pain, especially as you have to buy the whole set to get the failed one, what servos do you recommed, i have had several failures, (OK broken when crashed).
                          As my Twister 47 has just expired, i have just used two from that, but the next "Whoopsie" will mean new ones, any hints welcome.
                          TDR (in progress)
                          SAB Goblin 700
                          Vibe 90SG Vibe 500E
                          Kalt Baron30
                            Hi Kwickkwack your twister bell 47 has expired you got any useable bits left going
                            cheap
                            Gaza07
                            Trex 500esp 6s Beast-X V3
                            Trex 600esp 12s Beast-X V3
                            A few Multi Rotors
                              What you looking for?,
                              Basically one motor packed up took out the receiver, I will have a look and see, but what evers left will be available, I will take a look and get a list
                              TDR (in progress)
                              SAB Goblin 700
                              Vibe 90SG Vibe 500E
                              Kalt Baron30
