Hi all,
Yesterday I gone two main gears broken on the same day. The Pinion Gear is ok, no bends or anything wrong that I can see with it.
After the first one is gone, I though that was caused by the main shaft bended. So I replaced the main shaft, put another main gear and start flying again. Then after few minutes another main gear gone! Same issue as before. And again nothing wrong with the Pinion gear.
Now I'm worried about get another main gear broken.
I've noticed the Pinion Gear was a little bit loose with the main gear ... was not really tight. could that be the cause of this issue?
Any thoughts?
Here is the video from my helmet cam of the two main gears issue:
[ame]http://www.youtube.com/watch?v=YaWUK5Jv_V8[/ame]
Abner
Any thoughts?
Abner
) Sorry for the pic quality.
