HELI NEWBIE - Starting and idle issues
  • #31
    Your right Ade.
    I should have added that the QUK stuff is not really required.
    Mark
    sigpicx2
    Airskipper 50 - For sale
    • #32
      DONT Quick Uk a Shuttle,you may as well just throw your money down the nearest drain,not being orrible thats just the way it is
      • #33
        I used the QUK swash plate and guide and it was a VAST improvement over the standard one.
        Not sure about the rest.
        Mark
        sigpicx2
        • #34
          Good job I don't know what QUK is!!!
          I've had the heli idling nicer, but only with the power to the glow plug switched on. The moment I take the glow power away the engine stalls.
          I'm using GN-10 fuel - could it be the fuel?
          • #35
            Drive down to Ade and let him sort it out for ya, save a lot of time and effort
            Sponsored by CSM, Optifuel
            Your RC Heli World
            • #36
              Change the glow plug,get an OS 8 or Enya 3,it could also be rich at the low end but sounds like a duff plug..
              To roughly check the low end setting get the engine idling and rev it up a bit to clear excess fuel or starve it of fuel and start it back up.Pinch the puel line about an inch from the carb and observe what happens..
              Speeds up suddenly and cuts...Too lean
              Runs for about 2 seconds,speeds up and cuts...about right
              Runs much over 2 seconds....Too rich
              This is a rough starting point
              • #37
                Carver,
                i have seen this before, and even been down this road myself. its a great challenge to get something flying on your own but unless you know exactly what your doing its also a very risky road.
                these machines are have killed people and require respect.
                i did some damage to myself recently with a plane.
                http://www.rcheliaddict.co.uk/showthread.php?t=1778
                im not suggesting i do it all for you, I will just be around to make sure its done correctly and safely. Wont cost you much either.
                Ade
                www.accurc.com
                adrian@accurc.com
                This is an apple free zone
                • #38
                  I purchased an Enya 3 glow plug and now all is well.
                  Thanks for the tip Raptor50luvver.
