Being new to the hobby I am stuck.
I have finished building my Beam E4
, but:-
I spun up the motor checking blade tracking which was fine and then checked stick and servo movements and noticed my tail servo did not move (Spartan 760 with S9257), light came on and stayed constant on the Spartan but nothing from the servo not even an initial correction.
Is there an easy way to check for a fault?
I plugged the Spartan in via USB to check servo type which is correct, reversed as gyro is mounted under the boom, all else as default.
Could i have screwed up my Tx settings?
It was working yesterday as I was checking rudder throw.
HELP!
, but:-I spun up the motor checking blade tracking which was fine and then checked stick and servo movements and noticed my tail servo did not move (Spartan 760 with S9257), light came on and stayed constant on the Spartan but nothing from the servo not even an initial correction.
HELP!
