Calling All T-Rex owners
  • Calling All T-Rex owners
    Hi All,
    I’ve finally got my hands on a T-Rex 450 with transmitter £300
    Can you check out the speck? Is there any thing I glaringly need to replace?
    Also what spare parts are most likely going to be required if I crash?
    I know the Transmitter is only six channel but that’s what came with it so I’ll have to make do until xmass.
    Align Trex 450
    Futaba FF7 pcm/ppm Transmitter with charger and crystals.
    Futaba GY240 gyro.
    Align 2800kv Brushless motor with heatsink.
    Align 25A Esc.
    Align Full alloy swashplate.
    All align servos.
    Align 6 channel reciever
    Hardened main gear.
    Lipo saver alarm.
    Upgrade XL head and blade grips.
    Align 315 PRO wooden blades.
    Blue bump resistant under carriage
    1 1800mah align lipo, 1 2100mah align lipo, 1 2200mah lipo. all in good condition.
    Ark balancing charger with variable current charging.
    T-REX 450 SE HummingBird v2
    A Man can live about forty days without food, about three days without water, about eight minutes without air, but only for one second without hope"
    Hi,
    Transmitter is a good one, you wont need to change it. I think you'll find
    its 7 channel not 6. Also if it has the jog dial on the right near the screen
    its the 7c and unless you go scale it will be fine for everything you need.
    Only reason for 8+ channels are mostly scale stuff that needs retracts
    or other moving extra parts.
    Main Blades, Boom, Tail fins are the 1st things you'll probably kill.
    Not a bad buy spec wise either. As long as the batterys are good then
    you have a good bit of kit.
    Find a indoor Club and go get it set up or help learning to fly it!
    Also get BMFA insurnace as the T-rex can Bite and it will hurt.
    Club list is here:
    http://www.bmfa.org/clubs/clist.php
    Mark
    www.uavaerialservices.co.uk
    BNUCs - Operations certified
    CAA - Permit for Aerial Work
      Originally posted by infacto
      Hi All,
      Align Trex 450
      Futaba GY240 gyro.
      Align 25A Esc.
      All align servos.
      Hardened main gear.
      Lipo saver alarm.
      Sounds like a good buy.
      I had problems with the Align reciever... kept the servos chattering so replaced it with a Futaba. The Align servos aren't the best.. As soon as they go replace them with something better.
      happy flying.
        6 or 7 Channel can you tell?
        hope it works
        http://cgi.ebay.co.uk/ws/eBayISAPI.dll
        ?ViewItem&ih=020&item=300012093194&rd=1&sspagename =
        STRK%3AMEWN%3AIT&rd=1
        That doesnt seam right
          With transmitter aint bad at all
          Be aware, that the ESC is shakey- especially govenor mode. The reciever isn't good and the align servos are pants. But be ware of the ESC
          But you'll be fine and the rest of the stuff is fine. All in all I think you did well
          Is this it?
          T-Rex 700NP - Align 91HP - Hatori 938 - Kasama Header - Align 690Ds - Align DS620 Throttle - Align DS610 x 3 - Spartan DS760/Align DS620 - QuickUK Tail Grips & Header Tank - Reactor X - SwitchGlo
          Transmitter - Futaba 12FG G3 2.4Ghz
            Yes
            Hi
            Yes that is the one.
            infacto
