Just one more go...
  • Just one more go...
    I got caught out this evening.
    Been at work all day and had a go with the T-rex in the back garden when I got home. Did one pack - fine. Did second pack and noticed tail servo not quite set up. Tweaked rod length and flew (just once more) in normal mode. Took off - tail servo sorted... then it didn't respond.
    To cut a long story short, dead headed the wifes flowers and tried to cut a hole in the fence.
    I put the tx down and within seconds it bleeped the low battery warning bleep. I then notice the aerial was fully down and I hadn't touched it.
    Don't fly when your tired people!!
    PS... The T-Rex isn't mine. I have some explaining to do
    Cheers, Lee.
    Proud recipient of an EGS
    Thats really tough Leebert,
    hope the damage isnt too severe, and the pocket wont take too much pounding,
    best of luck in the future
    TDR (in progress)
    SAB Goblin 700
    Vibe 90SG Vibe 500E
    Kalt Baron30
      It amazes me how often people go to take off with helis or planes (one bloke in particular!) with their aerials down.
      I think it's all about routine - mine is I pull the aerial out before I turn on the Tx, before I turn on the model etc. It's not flash or fancy, it's just my routine which means I never make this elemental mistake.
      Touch Wood!
      The stupid thing that I have done on a couple of occasions is start a heli without having turned the model on! Thank God I always drop the throttle to idle before I turn it off!
      JR Vibe Fifty fb (YS56)
        Yikes, I be more worried about the missus hope there isn't too much damage. I was taught to pull the aerial out about a foot until the heli is ready and out at its take off point, then back away while extending to full length before commencing flying, easily done tho I rekon.
        Velocity 50
        Synergy N5
        Fury 55 FBL
        Trex 700
