How do you do a loop? please
  • How do you do a loop? please
    I no that I’m not ready yet but I would like to run it through my mind how you do a loop,
    Can it be done in normal mode or dose it have to be done in idle up mode,
    And what is the procedure.
    It makes it a bit more difficult cos I can’t run a sim on my Mac, so it has to be done for real!! (gulp).
    I will have to go over to Fast-Lads and have a go on their sim, and see if they can do the same deal as Leeds on a t-500 (Hint-Hint).
    Regards Chris
    Once your past the hovering stage you will need to be idle up really. Loop is done by forward speed then pull the stick back and up you go the just keep it there and the heli will go up over and back round you will need to drop off a bit of pitch on the invert part of the loop as well. you can get a feel for how much cyclic and pitch you need by doing the entries to a loop but turn them into stall turns. hope that helps.
    Dean
    www.midlandhelicopterclub.org.uk
      You need forward speed, and when you try it be in idle up mode so that you have some negative pitch (full negative helps). Suggest you have some decent altitude too, as you need it when coming down again. It's hard, but most of the difficulty is mental stuff. I remember my first loop (still my only loop) and my heart was in my mouth all the way.
      Speed, altitude and when you're ready, pull the stick back so the nose goes up, as you reach the top of the loop ( I used around half stick so that it looped, full stick will flip it), you should have the pitch in the middle, so zero blade drive, then as the heli goes inverted add some negative pitch to keep it up, then as it comes down so your pitch goes up again to middle, then to normal flying pitch as it comes off the bottom, if it's coming down a bit quick and looks like a crash is coming, then try a little more cyclic to bring that nose up level. If you get it wrong first go just try to do it erring on the side of safety first, then save the heli if you can. If you do it right there's no reason you can't keep the heli whole.
      I did mine with the curve set for fulll positive and negative pitch, it makes those kind of moves easy. Just make sure you are ready to try it, if you can do stall turns, you are half way there. So once you can do a reasonable stall turn and come off straight and level, I'd say that's when you will be ready, but that was what worked for me. I admit I did have a lot of practice on Phoenix first though. I knew the moves to make, it was just a matter of doing it for real.
      Let us all know when you plan on trying it, and make sure your first go is on a very calm day, mine was, dead calm, it was great. And I'm still smiling to think about it.
      John
      sigpic Proud holder of an Eddie Gold Star.
      Too many hobbies, not enough hours in a day.
        Thanks for that, I think I will wait a bit longer! And take all the carbon bits of before I try it. It dose make sense to get a sim but I would have to buy a PC as well the Phoenix, and the pennies only go so far.
        Regards Chris
          As John 'jboweruk' was saying its a good way to start but to sharpen the loops/rolls, in ya TX set the swash mix to the max you can go without causing any binding, I have my DX7 swash mix set elev 72% aile 72% but with these settings you will need a high head speed to prevent stalling so I find to get a nice lps/rolls i've set my idle up 0,100, 100, 100, 100, if this seems too much you can set it to 0,90,90,90,90, ptch can be set to 25,25,50,75,100 this allows inverted lift so long as you dont reduce stick below quater stick.
          • Flickr Through My Pictures.
            I was going to post asking the same question today. Just flew using idle up for the first time today, been flying stall turns in normal mode and itching to try loops and rolls now. May nip out at dusk and try loops if im feeling brave hehehe!
            Blade CX2
            Mini Titan
              My Mini-T for loops ect is set in TX swash mix aile 85% elev 85% so you wont need to give it full stick to get some nice rolls ect but you will need a high head speed as you will need to give bit of mid to inverted stick.
              Good luck.
                Good luck.
                OK, thanks mate. My tx swash mix is 65% for aileron and elevator, when doing stall turns it feels like the heli will easily loop if i keep the back elevator stick in. Im guessing rolls arent as easy as just giving it a good bit of aileron?!
                Blade CX2
                Mini Titan
                  I wouldn't recommend trying any new maneouvres at dusk, as you will really want all the light you can get to help with visibility. Once the light starts going the model can appear very "silhouetty" and it's very easy to become disorientated
                  Best of luck though, and let us all know how you get on
                  Phil OB3
                  Trex 450SE v2
                  Walkera 4#3b
                  DX6i
                  Phoenix
                  http://stratfordgliding.co.uk/
                  ...and proud owner of THREE!
                    Get high, get fast, give it some back elevator, hold it there, it will go over, it will loose hieght over the top but you can worrie about that later, height is the key, you want to be '2 mistakes high' ( thats an Edders statement but oh so true ). simple as that, not too aggressive with the sticks, plenty of forward speed, my first loops were done at full throttle, full pitch, high and fast.
                    And a DX8 too
                      I often fly at dusk, the wind often drops off nicely round here then, although now ive put it into idle up, the strong winds seem much less of a problem.
                      Blade CX2
                      Mini Titan
                        Hey guys,i did it, i just flew my first loops, read my other thread! Well pleased.
                        Blade CX2
                        Mini Titan
                          I did my first loops, back flips and inverted on wednesday just gone. I had a m8 video it.
                          [ame]http://www.youtube.com/watch?v=9MtpU9Do41c&feature=channel_page[/ame]
                          If you skip to 3mins 35secs you will see my first 2 loops, the first one I didnt easy off the pitch when upside down and the second one I eased off a bit too much.
                            Cheers Guys for all of you replays, I no what you mean about flying at dusk, I went out on Thursday evening 5.45pm it was alright at first, I moved round for a minute there was some big trees in the background and it just went in to stealth mode, all I could do was to throttle up and hope for the best, it worked thank god. So we live to fly another day.
                            Chris
                              http://www.youtube.com/watch?v=9MtpU...e=channel_page
                              Very good how long have you been flying, Looks well.
