Newbie problem - motor running at min stick??
  • Newbie problem - motor running at min stick??
    Hi guys
    I've just finished repairing my twister 3d storm and cannot figure out why my motor spins even when I am at min stick. I changed the min and max pitch of the rotors but kept my throttle and pitch curve the same so don't understand why this is happening. The only way I can stop the motor from spinning at about 25% revs is to use my throttle hold function.
    Any help would be great - thanks!
    Have you recently bound the Rx with TH on?
    Is TH set to below 0?
    Re-bind with throttle at min.
      set some throttle trim down then turn heli off
      put the trim back to centre and should be ok
      happened to me when i turned the heli and tx off when in throttle hold
      hope that helps
      Matt
      Current = Blade mcpx v2 + DX6i
      Future = 1st - PL6 + PSU 2nd - Chase 360 3rd - DX9 4th - Who knows...there's too much choice
      One Eddie Gold Starsigpic
        Thanks guys! Lovely job! I had turned off transmitter in th hold. All good now!
          gd gd glad your back as you want to be
          Matt
