Strange noise?
  • Strange noise?
    Hi All
    Just been flying aroung around practising for my A. The guys had previously set up my txer for idle up and I used it tonight. Thing is, when I descend slowly or reduce the pitch slightly when hovering (to about half stick) the exhaust note changes - it almost sounds like its rattling. One of the guys said it's running lean. I richened it up and the noise happens a lot less often. Do I need to worry or should I just get on and fly it!
    Raptor 50 V2 OS 50 sx-h (Not hyper)
    Cheers, Lee.
    Proud recipient of an EGS
    sorry i farted
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
      LOL!!
      Thanks Ade
      My return key has a hair trigger - I have re edited my post!!
      Cheers, Lee.
        idle probably too lean.
        Ade
        www.accurc.com
        adrian@accurc.com
          What, your arse or my engine LOL!
          Sorry - couldn't resist!
          Should I turn the small screw and leave the needle alone?
          What sort of amount should I adjust at a time?
          Cheers Ade.
          Regards,
          Cheers, Lee.
            i have never seen a hyper do it.
            what fuel
            muffler
            plug
            are you using and what is the needle and screw set to?
            Ade
            www.accurc.com
            adrian@accurc.com
              Hi Ade,
              Magnum 12 % Fuel
              standard OS exhaust
              OS No 8 plug
              Screw set central (near as makes no odds)
              Needle set approx 1.6 turns out.
              I tried richening up the screw (didn't notice anything except had to knock the trim up a bit otherwise it stalled). I also tried opening up the needle valve a couple of clicks as well - it now only does the noise occasionally but it then struggled with a full pitch climb out
              Cheers, Lee.
                Hi Ade
                Will fly again Sunday afternoon and report back. I have richened the low end slightly and will see how she flies.
                Watch this space!
                Cheers, Lee.
