charging a dx7
  • charging a dx7
    hi all, got my dx7 this week and bought a charger for it too.
    how do i know when its fully charged. i read in the manual 16hr but is that from a flat battery or is that bought right.
    http://hobby-hangar.co.uk/product/sp...mains_charger/
    this is the charger i bought.
    Jonathan
    trex 600
    Trex 450 v2
    and an
    You have to assume that a cell might be flat as NiMhs can discharge fairly quickly. Mine gets up to about 11.5 volts. We used to overnight charge before flying when we had 500mah NiCds in the tx. They talk about forming the battery, don't know what it means though. If you let one of the cells go flat, then all the others gang upon it and make it go reverse polarity. Best to get a new battery then.
    Chris
    Blade 130-X, MSR, MSRX
    Phoenix Sim
      My first DX7 battery only went up to 10.0v, turned out to be a duff cell. The new one will go to 11.9v but will only hold this level for a short while, dropping back to 11.5 or 11.6 volts.
      hope this helps.
      Si
        Stuck a 3S Lipo in mine now here
        Lasts forever and no probs.
        Charges on my cellpro 10S
          i have been using the outrage battery machasm mentioned in my 9x2, i get 10hrs "on" time per charge, the dx6 should be similar amount of time.
          when it gets to 11.0v you have about 1hr useage left, when it gets to 10v stick it on charge.
          Ade
          www.accurc.com
          adrian@accurc.com
          This is an apple free zone
            I took the FP option with mine when I had it as I found the tx batt was absolutely naff at holding its charge.
            Got mine from Midland
            Stuart
              Lipos are much more predictable than NiMhs as we know the voltage of each cell. There are new Nimhs that keep their charge for much longer. Hybrio is one brand. Nimhs are a pain. They shouldn't be slow charged above C/40 and they give false peaks that can stop a charge too early.
              Chris
              Phoenix Sim
