Why does my heli settings change daily!
  • Why does my heli settings change daily!
    Flew my heli yesteday went fantastic! flew it this evening it had a high head speed no lift! it went to 2/3 stick before it even got light and the engine was screaming as it had no load, All linkages are ok, feathering spindle is straight, engine is running fine, after a good check over all appears well, and a quick check with the pitch gauge shows 10degrees at hitop end and -5 at the other.
    I havent changed my pitch curves since a great flight yesteday Im reluctant to play with the pitch/throttlw curves as it worked perfectly yesteday
    Im so confused,
    Can anybody help, its a shame to have troubles when weather is so good.
    Andy
    Happens to me every time I forget to disable the little trip tab thing on the left side of my transmitter (JR9X) - its a pitch trim.
    Clones are bad
    .... that includes Align ones
      check the clutch
      Dave
        Hi Tom
        I have the same TX and have disabled that trim switch, but that was a problem when i didnt know about it!
        Have checked the clutch dave and there is plentey of meat on the liner and the shoes!
        Andy
          Idle up switch (Flight Mode) switch ON but not set up ?
          Janek
            Thanks for your help chaps, After looking through my tx settings i found that i had somehow changed my pitch travel settings, Was only using 7 degrees at full stick, no wonder it screamed!!!!
            Andy
