BuzzFly Problem
  • BuzzFly Problem
    Hi
    My BuzzFly has developed a problem.
    Normal flight requires about 1/3 throttle to maintain take off and hover until the battery goes - normally 8-10 mins.
    Connect up fresh battery today and it required half throttle to get off the ground and up to 3/4 to hover. It would only fly for 1 min before it could not get off the ground.
    Tried spare battery - same
    recharged battery 3/4 hr (normal) - still the same
    I am thinking main motor problem, what do you think (nothing rubbing on main drive)?
    Buzzfly SE
    Beam E4
    TRex 250SE
    yes you would be right in thinking the motor is shot
    walkera 4#3a full brushless
    walkera 4g3 soon to be brushless
      Had the same trouble with my 4g3 i did the same recharged the battaeris still the same head speed is lower than normal im guessing motor so ive shelved it till the brushlees gear comes down in price
      i now it doesnt help you much but its nice to know im not alone
      Cheers jim
      Cheers all Jim
      Beam e4 I LOVE IT
      Trex 450 Airwolf in progress
      walkera 4g3(complete pants
      Blade MSR Quality
      speccy dx6i
      PROUD OWNER OF 1 EGS
      If it flys fly it if it doesnt fly drink it
        because of the size of the buzzfly to keep the weight down the motor isnt quite as big as maybe it should be for ultimate reliability.
        so basically they dont last forever, the brushes wear out and they loose power.
        its a cheap and easy job to replace them and as long as you shut the power off as the blades hit something solid they should last plenty of time.
        Ade
        www.accurc.com
        adrian@accurc.com
        This is an apple free zone
          A small squirt of WD40 into the motor (and not the 4 in 1) seems to double the motor life according to another forum. I've tried it on a failing motor and it gave me another 15ish flights.
          HKH-450,
          Spektrum DX6i
            Thanks for the comments, I'll get one on order.
            Buzzfly SE
            Beam E4
            TRex 250SE
              I'd also suggest letting the motor cool down between flights.
              Though I have no definitive evidence that this makes a difference.
              Yes, it's th@ tw@ Scallyb@...
                Mine was the same, get yourself a heat sink and cut out the canopy at the top a bit bigger to let more air flow over the heat sink. Still on my second motor after plenty more flights than the first
                Edit: take the sticker off the new motor before putting the heat sink on. Metal to metal is far better than metal to foil then glue and then metal :-)
                Blade 400
                Buzz fly Se
                www.helpforheroes.org.uk
                  These chaps are good for cheap buzz fly / walkera stuff.
                  http://www.hobby-wing.com/
                  Blade 400
                  Buzz fly Se
                    Thanks Guys
                    Got my motor and a few spares today - from www.rc-bargains.co.uk/
                    Fantastic service, all parts with postage included.
                    Slapped the motor in and back to normal Yippee
                    Had a look at the site above - cant wait for the bushless motor conversion to become available in UK.
                    Buzzfly SE
                    Beam E4
                    TRex 250SE
                      Definately the motor mate.
                      Look at fitting a heat shield on the next one.
                      See my large thread on the subject!... hours of informative reading!!
                      PROUD OWNER OF 4 EDDIE GOLD STARS!!!!!!
