Wooden blades
  • Wooden blades
    Hi,
    Getting more confident with my mini titan now, and starting to do fast forward flight and stall turns etc. Im currently using the stock thunder tiger wooden blades and they feel a bit flimsy and flexy, and you can really hear them working when the heli manouvres about. Are the wooden blades up to being clumsily thrown around the sky, or should i upgrade to carbon fibre?
    Cheers.
    Blade CX2
    Mini Titan
    I think I'd upgrade to CF if I were you - there's a huge difference in performance with them
    Phil OB3
    Trex 450SE v2
    Walkera 4#3b
    DX6i
    Phoenix
    http://stratfordgliding.co.uk/
    ...and proud owner of THREE!
      I have SAB blades on mine and it flys a treat with them
      TDR (in progress)
      SAB Goblin 700
      Vibe 90SG Vibe 500E
      Kalt Baron30
        Yup time for a change to carbon .. and then you can up the headspeed as well .. Me I use JP carbons on my Titan .. But after flying the Torsions on my Knight it looks like the Torsions will be going on the Titan as well ... and they only £5 more as well .. result ...
        Knight 3D
          I had SAB blades on my Trex and they were great, but died on Monday. (They didn't fare too well hitting the ground at 2800rpm)
          Just putting new Radix on it in a minute
          Phil OB3
          Trex 450SE v2
          Walkera 4#3b
          DX6i
          Phoenix
            Thanks guys. Im assuming carbon blades are stiffer/stronger than wooden blades? The way the stock ones flex doesnt really inspire confidence in their strength, im concerned they will break in flight if im less than delicate with the throttle/collective!
            Blade CX2
            Mini Titan
              Yep - got it in one
              Phil OB3
              Trex 450SE v2
              Walkera 4#3b
              DX6i
              Phoenix
                Must have been a duff set
                Take them back under warranty
                TDR (in progress)
                SAB Goblin 700
                Vibe 90SG Vibe 500E
                Kalt Baron30
                  That was going to be my next question! I recently fitted a scorpion -8 motor, which has a slightly higher kv rating than the stock one it replaced. I guess a better blade will be more reliable at a higher headspeed, and make more efficient use of the extra power?
                  Blade CX2
                  Mini Titan
