How do I.... Hover Inverted!
  • How do I.... Hover Inverted!
    Guys,
    I have got loops, Barrel rolls (well kind of) about sorted.
    So if I can get the heli inverted now what alters on the controls
    from the heli being the right way up.
    Remeber No Sim to try this out on. So I need an idea whats going to
    happen. I can hold a Heli upside down as I found out lucky enough for me
    but I would like to have it closer than 150ft away inverted with me having
    a bit more control as well!
    any tips/advice welcome
    Mark
    www.uavaerialservices.co.uk
    BNUCs - Operations certified
    CAA - Permit for Aerial Work
    Im nowhere near that stage but I've heard a technique where you go into a loop and then slow up at the top. The pause gets longer and longer until you're hovering inverted. (sounds easy doesn't it )
    I might be talking **** but I'm sure someone on here will correct me!
    Cheers, Lee.
    Proud recipient of an EGS
      I found there are three things that change, ther elevator is reversed, the rudder is reversed and the heli is much further away than usual . I found that flying inverted at the top of the loop for a bit helped as you just worry about the left and right - just need the courage to get the thing a little closer.
      Another thing is to have a get out plan, I was told left stick down and right stick up which is fine for nose or side in, but tail in and it come towards you, but that method will teach you tick tocks without you realising it.
      Clones are bad
      .... that includes Align ones
        thats one way. another way is to do a forward flip, hold it nose in inverted then flip it back out before it goes too far wrong.
        Ade
        www.accurc.com
        adrian@accurc.com
        This is an apple free zone
          I'm currently learning inverted hovering, but I went for a roll into it, therefore I'm doing tail-in first , it's gradually getting closer and lower, but the control that messes up the brain the most is the tail
          Also watch out for wrong sticking when you go back to upright flight, particularly backwards upright, as I've had a couple of close calls wrong sticking the elevator and doing inadvertent tail slides
          Janek
