Newbie - Indoor vs Outdoor
  • Newbie - Indoor vs Outdoor
    Hello all,
    I've just signed up to RCHeliAddicts today! I got a Blade CX2 at Christmas, and am LOVING IT!!!
    I had a few questions..
    Firstly - can anyone explain (or direct me to a posting) what the main difference is between indoor and outdoor heli's?
    I used to think it was mainly the weight meant that wind didn't have as much impact, but the current outdoor helis can be very light.
    so then I thought maybe there are more gyros and electrics that counteract the wind?!
    Just curious to know what would stop a Blade 400 from being sent haywire like my CX2 does when I try taking it outdoors!
    Also - in a few months when I've mastered my CX2, I'm keen on stepping up to an outdoor model... so I was wondering if anyone can suggest a very cheap place to find a good Sim? Ebay? 2nd Hand?
    Also, will my CX2's transmitter work with SIMs, or will I have to spend more on another one?
    Thanks everyone!!
    (and sorry... I'm sure similar questions are asked very often!)
    hi and welcome to the forum,
    phoenix sim is a great starting point
    adie
    adieuk
    x7 eddie gold stars!
    www.eaglerc.co.uk
    dx7, phoenix sim
      depends how strong the wind is pal they all go haywire in the wind but gyro helis are a bit more stable
      adie
      adieuk
      www.eaglerc.co.uk
      dx7, phoenix sim
        Originally posted by immortalDaz View Post
        Hello all,
        Thanks everyone!!
        Indoors tend to be the smaller machines the contra's cannot handle wind for example they just get blown about and crash which is fine with me
        450 size are mostly used indoors but they can handle winds of 8-10mph winds if kitted out right.
        why doesn't the 450 suffer like contras its because it has one set of blades spinning a lot faster. wind gets hold of a contra it just pushs it along the blades are fixed pitch where as the 450's have a Collective pitch and you have far more control over the blades and head speed etc etc.
        Outdoors mostly Nitro or larger electric (T-rex 500 size and up)
        Sim buy Phoenix its 80 pounds and not expensive
        Mark
        www.uavaerialservices.co.uk
        BNUCs - Operations certified
        CAA - Permit for Aerial Work
          And yes, the LP5DSM will work with Phoenix, but I find the DX6i is better.
          Martin
            nicely posted disc
            adieuk
            www.eaglerc.co.uk
            dx7, phoenix sim
              Originally posted by adie171165 View Post
              nicely posted disc
              Dam I forgot to say can everyone with a contra please fly it outside on sunday
              (only joking please don't!!!)
              Mark
                Welcome to the forum!
                Just in case some of the other posts don't make sense, I'll fill in a few blanks. My apologies if you already know this!!
                The blades of contra rotating twin blade helis like the CX2 are fixed to a positive pitch angle, so the lift depends on the speed of the blades and the amount of air passing over them. This is OK for indoors as there is zero wind even though you have to lower the speed of the motor to descend.
                Outdoors in wind its a nightmare because the positive pitch on the blades will make it climb if the blades are spinning at almost any speed which makes descending a bit tricky to say the least.
                On a collective-pitch model you can vary the pitch of both blades simultaneously to either positive pitch (to climb) or negative pitch (to descend). This allows the blades to spin at a constant rate improving stability and allowing descent in windy conditions.
                I fly my Blade 400 in reasonable winds, although the bigger and heavier the heli, the less they will be affected by wind.
                Hope this helps, and anyone feel free to pitch in if I've got it a bit wrong!!!
                Blade 400 / DX6i / Phoenix / Blade CX2 / mCX / MSR
                Proud Owner of 2 Eddie Gold stars
                  Thanks Everyone.... expecially HeliTV... that all makes sense... but it has also scared me!!
                  So on my Blade CX2 I use the left stick for throttle to ascend and descend... so for a collective pitch, would I use the throttle (left stick) just for rotor speed? if so, how do you control the pitch for ascending??
                    No no, the left stick will control both throttle and blade pitch.
                    T-Rex 600 LE & T-Rex 500 ESP
                      Nicely explained mate.
                      sigpicWayne AKA OB1
                      Plus 3 Eddie Gold Stars, yay!
                        Welcome to the forum mate, I'm pleased your CX2 is offering much enjoyment, and so may it continue.
                        Always remember this hobby is one continues long learning curve, so don't worry about asking possible questions that have been mentioned before, everyone has to start somewhere.
                        As said, the controller with your CX2 will work fine with Phoenix, and if you seriously wish to take your hobby to the next level you want to make that your next purchase.
                        Good luck.
                        sigpicWayne AKA OB1
                          this guy might lol
                          turbine contra lol
                          Simon
                            I think he just had a mismatch of trying to explain that left throttle powers up and lifts, and the right directs what direction she flys.
                            sigpicWayne AKA OB1
                              Originally posted by SimonV6 View Post
                              this guy might lol
                              turbine contra lol
                              Simon
                              With a Turbine strapped to the arse of any Heli would enable it to fly through even a Baked Beans Factory and stay in one piece.
                              sigpicWayne AKA OB1
