Heli piro left uncontollably
  • Heli piro left uncontollably
    I've got my CP pro/HDX 300 belt drive upgrade all put together. But she piros counter clockwise. this is how it is set up and what I've checked:
    1) Belt is tight
    2) tail rotor is spinning counter clockwise/main is clockwise
    3) right rudder input servo arm moves forward
    4) rotate heli left, servo arm move forward
    5)tail slider attached to leading edge of blades.
    6) with right rudder input, tail blade leading edge moves left and
    vise versa.
    7) 10 plus degrees of pitch full right
    8) oneway bearing is functioning correctly
    Am I missing something in my irritated state of mind?? ok,ok irritated/medicated state of mind..
    heli has:
    370 brushless inrunner motor/ 25 amp ESC (Eflite suggested motor and ESC for upgrade) as well as a eflite 110 gyro. tail servo is S3254 cyclics stock eflight 75's. AR6100 reciever.
    Job?? We don't need no stinking job!!!
    Reading your list of setup points above, it looks like it is mechanically working the right way and electronically setup correctly.
    Based on that, I guess it is not a stupidly fast pirouette we're talking about here?
    I'm thinking a steady pirouette??
    If so, it would suggest the mechanical linkage isn't quite set right.
    That, or the gyro isn't any good?
    | 3D Championship
