I have an esky honeybee cp2. was a crimbo present. Well anyhow i crashed it, like you do lol. my main rotors have slight damage (chips out of sides) and my tail rotor has a chip in it. When i give throttle the tail tries to spin one way, however when i get full power it just spins out of control. there is no correcting it. i am confused lol. also it tries to pull back alot. any help wud be great. Cheers
Help me please?
Confused newbie
You will need a lot of time and a lot of practice to be able to even hover. Even then you will only be at the start of learning. Read through this forum and look for mcx and Phoenix sim. If you can find someone local you can ask them to have a look at it or the model shop should be able to help.Originally posted by craigyard123 View PostI have an esky honeybee cp2. was a crimbo present. Well anyhow i crashed it, like you do lol. my main rotors have slight damage (chips out of sides) and my tail rotor has a chip in it. When i give throttle the tail tries to spin one way, however when i get full power it just spins out of control. there is no correcting it. i am confused lol. also it tries to pull back alot. any help wud be great. Cheers
ChrisFlasher 450 Sport. Assan GA250 with 520 tail servo, MKS DS450 cyclic.
Blade 130-X, MSR, MSRX
Phoenix Sim
Originally posted by cjcj1949 View PostYou will need a lot of time and a lot of practice to be able to even hover. Even then you will only be at the start of learning. Read through this forum and look for mcx and Phoenix sim. If you can find someone local you can ask them to have a look at it or the model shop should be able to help.
Chris
i flown the 4ch honeybee before, could hover and that. just wanting to know why its doing what its doing. the bloke in my model shop said he didn't know anything about the honeybees, so am lost.
craig,
It could be a number of things .............you have to narrow it down.......I am guessing the tail is spinning anti clockwise which suggests the tail motor is damaged .......as the post before suggests ..... read and learn
all the best mateTHERE IS A DIGNITY IN SILENCE....
BUT A LIKE MY RAPPY'S
Ok. That's not a problem that can't be sorted out. Shame about the model shop. First thing then is to find a good heli shop you can get to.Flasher 450 Sport. Assan GA250 with 520 tail servo, MKS DS450 cyclic.
Phoenix Sim
Have you got training gear? If not get some and run it up slowly on a smooth slippery floor and post a vid.Flasher 450 Sport. Assan GA250 with 520 tail servo, MKS DS450 cyclic.
Phoenix Sim
