Hey guys how it going.
So i thought id check out the net 4 sum help.
I bought a belt cp 3 weeks ago and have only had bout 20 seconds flight!!!
The day i got i waited 4 the battery to charge all excited like a kid at x-mas.
WOO HOO green light! but i plugged the battery on chopper b4 turning on remote (mistake 1) heli had a spaz and spun up in the lounge, blades hit couch and main gear is shed. 3 day wait 4 part.
of course my heli came with a pre stripped hex head screw 4 main gear so i had to take entire thing apart 2 to get at gear, put it all back together but got tail belt twisted. (mistake 2) no points 4 guessing that it was rather indecisive bout witch way it wanted to go and had a bad landing, (bent boom and broken tail suports) 3 day wait.
got new boom and supports spent ages trying to get it lifting up straight adjusting things only to find front servo was not working. 3 day wait.
got new servo and actually got it off the ground but b4 i could try trimming anything a rouge wind introduced it to a steel container at work, dont fly in wind (mistake 3) 3 day wait 4 flybar holder.
So i get flybar holder AND buy a tiger training kit thinking it will help and it did, kinda. put it all back together, get blades traking wonderfully and just tried to get it cumming up straight and i was gettn there, little hover, quick trim, hover again. Then for some reason when i was hovering bout 50mm off ground (heli was not perfectly still but i was slowly tweaking it right) i cut throttle and the blades sumhow hit boom when it came down. it took the laminate off blades so i replaced them, now when i spin it up it just shakes like a nervous long tailed cat in a room full of rocking chairs. Y? tracked blades properly, main shaft no visibly bent. HELP please. I know its a bit of a life story but i just wanted to get it out there and was wondering if anybody else had problems like this?
If your reading this then thanks for reading my novel!
peveral_othman
peveral_othman
(You will need a blade balancer for this, or clamp the two blades together with a long bolt and balance between two beer glasses). Those Esky blades often are not balanced and could well be the cause of your vibration.
