Starting Gear Price
  • Starting Gear Price
    Hey All, Hopefully ile have my PC sold so ile have my DX7
    But now i need the starting gear and equipment, i should have around 80 to £100 at xmas i was going to get the Thunder Tiger Carry Master that it includes everything i need but i was told it maybe underpowerd.
    Any suggestions?
    regards
    Callum
    www.callumheli.co.uk
    I would look into buying the bits you need separately. I'm not sure of the quality of the starter in that package, maybe someone who has used one could comment.
    Personally, I would look at the Sullivan starters - probably a Hi-Tork (black and yellow) for your needs.
    Outside of that, you need a glow driver and a power source (12 volts) of some sort. Your car battery would do at a push...
    | 3D Championship
      don't forget a fuel pump (around £10) and fuel
        Battery drill with reverse if you already have one.
        Sawn off ball ended allen key to go in it.
        Glow driver with charger - £10?
        No 12V needed.
        Fuel pump £10
        Spend the rest on fuel.
        I'm not a beleiver is spending on field kit. If I wasn't flying on my own so much I'd be on the borrow for other folks starters...
          I have the thunder tiger carry master which i got with my raptor 30...they are ok for a 30 size motor but struggle a bit with a 50..so since upgrading to a 50 v2 I have done as moyesboy has...reversable cordless drill.
          Raptor 50 v2 - OS 50 Hyper - Spartan Quark - DS 650 - DX7
          Raptor 50 Titan SE - Redline 53 - Spartan DS 760 - DS 650
          Mini Titan e325 - Spartan DS 760 - 6100e - Huey Fus
          Phoenix
          Holder of 2 EGS
          Need a DJ? www.soundmachinedisco.co.uk
            You dont have to pay big bucks for your starting equipment if you are willing to keep an eye on ebay etc. I picked up my starter (Sullivan Hi-torq) for 20 quid!
            Regards,
            Jason
              glow drivers/ starters are in the heliaddicts auction site really cheap at the moment with chargers
              Mark
              www.uavaerialservices.co.uk
              BNUCs - Operations certified
              CAA - Permit for Aerial Work
                I'm very popular at our field because I have the Sullivan Hi Torque starter.
                Its still turning them when the others have given up.
                I bit like the duracel bettery advert.
                  The best starter out there, IMO
                  | 3D Championship
                    Yeah.
                    I know a bloke that turned up at my place to fly and his Hi Torque looked liked it was 20 years old and well battered.
                    Still did the job though.
                      LOL
                      No point having it if you don't use it
                      LOL
                      | 3D Championship
                        Indeed.
                          Thanks All,
                          Seems alot cheaper then i expected. My dad has an electric cordless drill someware down the shed.. so ile digg that out and buy the rest soon!
                            If going the cordless drill route, make sure it spins fast enough. I've not used one myself, but seeing others use them, sometimes they struggle to start the engine due to it not spinning fast enough.
                            I'm not sure what speed "fast enough" is, which isn't much use to you I realise, but I thought it worth pointing out. Perhaps those that do use this method can tell us what speed their drill spins at
                            | 3D Championship
                              My drill was fine until the moor got a bit worn. A new motor with good compression doesn't need to spin fast.
                              also cloing off the exhaust for a few tunrs can get it going a bit better if is slow.
                              Remember not that long ago all this type of motor were started by flicking the prop with a rubber protected finger...
