I need a few new parts for my Spyhawk (Not Skyhawk as I previously said) Im not sure what they are called due to the instructions being a really bad photocopy. I have got a pic of e-bay for one part (see link below, the two sticking up bar type things, cirlcled in yellow )
www.miketrevor.co.uk/skyhawk.jpg
The other part is the part that you screw the 2 main rotor blades on then clip it onto the top metal thingy. I also need the plastic case which i think is EH18 but im not sure can anyone confirm this? And the last part is the landing gear (poss EH49??)
Im sorry it sounds really dumb that i dont know what these parts are called, i have Pasted a list of the parts available from my supplier in the hope that someone can identify which parts i need.
Thanks in advance
Mike
EH 1
Main Rotor
(1)(54) x 2
21.20
EH 2
Rotor Head
(2) x 1
6.80
EH 3
Single Hole Tie Bar (short)
(3) x 2
3.40
EH 4
Rotary Sleeve Spindle
(4) x 1
6.30
EH 5
Main Rotor Ball Bearing
(5) x 2
5.50
EH 6
Internal Control Panel
(6) x 1
5.50
EH 7
Double-Hole Tie Bar
(7) x 2
3.40
EH 8
External Control Panel
(8) x 1, (49) x 2
6.30
EH 9
Stabilizing Wing Beam
(9) x 1
6.80
EH 10
Internal Tilting Panel
(10)(12)(13) x 1
16.80
EH 11
Single Hole Tie Bar (Long)
(11) x 1
3.40
EH 12
Servo Tie Bar (Short)
(14)(15)(16) x 1
3.40
EH 13
Stabilizing Blade
(17)(49) x 2
6.80
EH 14
SRM-102 servo
(18)(47) x 2
62.40
EH 15
Main Rotor Motor Kit
(19) x 1 (26) x 2
12.80
EH 16
Board Cover
(20) x 1 (47) x 4
3.40
EH 17
Framework
(21) x 1 (32) x 2
10.20
EH 18
Casing
(22) x 1
7.50
EH 19
Battery
(23) x 1
22.6
EH 20
Foot Pole Support
(24) x 1
12.20
EH 21
Main Shaft
(28)(42)(48) x 1
6.80
EH22
Driving Gearwheel
(29) x 1
5.60
EH23
Battery Holder
(30) x 1 (35) x 2
5.60
EH24
Tail Boom
(31) x 1
9.40
EH25
Casing Pole Support
(33) x 1
4.80
EH26
Tail Stabilizing Wing
(34) x 1
5.50
EH27
Tail Fastening Sleeve Spindle (Right)
(36)(37)(42)(45)(27) x 1
3.40
EH28
Tail Rotor
(38) x 1
6.80
EH29
Tail Rotor Gearwheel
(39) x 1
5.50
EH30
Tail Rotor Ball Gearing
(40) x 2
4.80
EH31
Tail Holder
(41) x 1
6.30
EH32
Tail Rotor Motor Kid
(43)(46) x 1 (44) x 2
9.50
EH43
Radio Transmitter
56.80
EH44
Receiver
38.00
EH45
Speed Control/Mixer
32.60
EH46
Gyro
61.00
EH47
Inside Charger
22.50
EH48
Outside Charger
22.50
EH49
Train Landing gear
28.5
EH50
Heat Sink for Tail Motor
2.30
EH51
Heat Sink for Main Motor
3.40
Thanks in advance
Mike
EH 1
Main Rotor
(1)(54) x 2
21.20
EH 2
Rotor Head
(2) x 1
6.80
EH 3
(3) x 2
3.40
EH 4
(4) x 1
6.30
EH 5
(5) x 2
5.50
EH 6
(6) x 1
5.50
EH 7
Double-Hole Tie Bar
(7) x 2
3.40
EH 8
(8) x 1, (49) x 2
6.30
EH 9
(9) x 1
6.80
EH 10
(10)(12)(13) x 1
16.80
EH 11
(11) x 1
3.40
EH 12
(14)(15)(16) x 1
3.40
EH 13
Stabilizing Blade
(17)(49) x 2
6.80
EH 14
SRM-102 servo
(18)(47) x 2
62.40
EH 15
(19) x 1 (26) x 2
12.80
EH 16
Board Cover
(20) x 1 (47) x 4
3.40
EH 17
Framework
(21) x 1 (32) x 2
10.20
EH 18
Casing
(22) x 1
7.50
EH 19
Battery
(23) x 1
22.6
EH 20
Foot Pole Support
(24) x 1
12.20
EH 21
Main Shaft
(28)(42)(48) x 1
6.80
EH22
Driving Gearwheel
(29) x 1
5.60
EH23
Battery Holder
(30) x 1 (35) x 2
5.60
EH24
Tail Boom
(31) x 1
9.40
EH25
Casing Pole Support
(33) x 1
4.80
EH26
(34) x 1
5.50
EH27
3.40
EH28
Tail Rotor
(38) x 1
6.80
EH29
(39) x 1
5.50
EH30
(40) x 2
4.80
EH31
Tail Holder
(41) x 1
6.30
EH32
9.50
EH43
Radio Transmitter
56.80
EH44
Receiver
38.00
EH45
Speed Control/Mixer
32.60
EH46
Gyro
61.00
EH47
Inside Charger
22.50
EH48
Outside Charger
22.50
EH49
Train Landing gear
28.5
EH50
2.30
EH51
3.40
