Hi all again,
Sorry if this has been posted before, but this is something that all you Raptor 30 users must know, if you're building one from new, and putting an OS 37H Engine in it...
Make sure that when you install the engine, you take off that little black carbon washer that is on the engine shaft. If you don't you will run into serious problems after your first engine run. (I can't explain what happens, but Nigel at Heli-Lessons.com will be able to tell you what happens)
It's not something that's covered in the manuals, so beware!
Best,
Si
Best,
Si
ops:
