Gain Help plz .....
  • Gain Help plz .....
    Hi can any 1 help
    Just want to know if this is right i have a twister v2 and thay say in the instructions that the gain should be right at 90% but if i do my trim is all the way to the left :S
    I have to turn the gain to about 10% to stop the tail spining and so the trim is nere the middle more.
    So im i doing it right or am i doing it wrong any info will be Cool ...
    i assume the twister is the same as other fixed pixed micros.
    You should have 2 adjustments. one is gain and one is tail mix.
    Gain affects how hard the gyro tries to stop the tail moving to sudden movments. The mix adjusts how much power is put to the tail to counter the torque from the rotorhead.
    It sounds like your adjusting the mix as too much mix will make the nose go to the right and not enough will make it go to the left. Low gain will make it feel soggy, high gain will make it wag.
    hope this helps.
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
      Hi ade yeah it is the same as other FP
      And thanks very much for the info
