CP to FP?
  • CP to FP?
    I bought a CP Pro and a 400 3D. should I have gotten a fixed Pitch before going to a CP? and if so, can you convert a CP to a FP, fo the time being. you can respond in Engish or american(little humor there!!)hahaha
    Job?? We don't need no stinking job!!!
    not sure if thats possible, don't think anyones botherd trying.
    maybe just put the 400 to one side for now and buy a blade cx2. once mastered move onto the B400 ?
    think you;ll find the conversion is more hassle than its worth! lol
      Surely if you want a FP heli, then just make the pitch curve the same value all the way along, so it will stay at you chosen pitch regardless of throttle position?
      Oli
      Oli
      Raptor 90 and a Raptor 30
        I do have a CX2 also, sorry should have mentioned that. It isn't very challenging to me. My G3.5 however, geeeez. Some days you can hover with absolutely no problem, other days, I couldn't hover if there were hanging on a string. Also the Sim doesn't seem very realistic for take off and ground effect...any suggestions?
          yesss.... i guess that would work... lol
          ignore my previouse post.. i didn't really think about that
            Oli,
            That makes sense. I'm only questioning all of this because I read fixed pitch was the next step. Apparently my LHS felt differently.
              Really what are the pro's and cons?
                In my opinion i would get on the sim, practice with your cx2 then go for it with the CP 400, I dont think it would make it any easyer to fly converting it to FP (i may be wrong), Just get someone to set it up to be nice and gentle for you.
                Oli
                Oli
                  if you have truly mastered the cx2( can you hover it in any orientation without thinking !! fly it to its limit without getting a blade strike??) if so the blade400 is ideal for your next step read up as much as you can in the 400 forum ... ask questions... practice on the sim realistic or not it helps!! and most of all persevere it will pi$$ you off at times , crashes can demoralise you .. but dont give up learn from every experience this is a truly rewarding hobby wether your a good pilot or not
                    The Blade 400 is a BIG step up from the CX2. Take it very easy to start with and for me, the learning curve for CP helis was and continues to be steep!
                    All the best
                    Blade 400 / DX6i / Phoenix / Blade CX2 / mCX / MSR
                    Proud Owner of 2 Eddie Gold stars
                      Boggy,Oli, fatmantom,
                      I really appreciate your insight and words of wisdom. I'd rather get advice and learn. I've already been down the crash and burn learning. Hence, the Simulator and the CX2. Although, some days I can hover, nose in nose out, side facing without a thought, and others I couldn't hover if she were hanging on a string..HAHA!
                      Again,
                      thank you
                        dont worry dude we all know that feeling!!!
                          Me too - now if I only knew WHICH days I couldn't do it before the crash, I'd be rich!!!
