ooops
  • ooops
    Hi,I was just wondering if there is anything i need to look out for when stripping and rebuilding my cp gold.I made the mistake of taking it out today and guess what....i crashed. it need a new set of skids,boom supports,and main gear .Wont be making that mistake again.Any advice would be welcome.
    Jim
    Check the shafts - main shaft, feathering spindle and tail output shaft - to make sure none of them are bent - not even fractionally.
    If in doubt, replace them.
    Flybars can be bent straight if they're only dinked a little bit - otherwsie replace that too.
    | 3D Championship
      what is the feathering spindle??
      Jim
        The rod that fits in between the blade grips.
          cheers,
          when i go to rebuild the heli is there anything i need to do or do i just put it back together the same way i disassembled it.
          Jim
            just make sure you use thread lock on any metal to metal threads
            Trex 600E
            Blade MCP-X
            Dx6i/Chainlink UHF
              thanks balders,
              when i was checking the feathering spindle i accidentaly bent two washers.will this affect it or can i put it back together with one less washer on either side of the rotor clamps.
              Jim
                You will need to replace the washers if you cant flatten them!
                ONE Eddie Gold Star!
                Kinross Radio Model Flying Club
                  looks like i'll be taking a trip to the hobby shop.already put them in the bin
                  Jim
