exhaust nuts & threadlock
  • exhaust nuts & threadlock
    Having recently finished my Trex 600n build, with everything threadlocked, I think I've now found out that I shouldn'tve threadlocked the nuts that hold the exhaust onto the engine!
    The info I've recently been told is that treadlock under heat will liquify, so when the nuts now become loose, the threadlock acts like a lube & helps em slip off that much better.
    Is this correct?
    Zoom, rather than worry about it just fetch them out and give them a clean. A nice fine smear of 5 minute epoxy on the exhaust works lovely!
    Andy
    sigpicX2
      There is no need for thread lock on the exhaust. Most exhausts don't have lock nuts and the screws do not come undone. The screws that hold the head, backplate and carb require no threadlock and they do not come undone.
      If for extra security or because your exhaust is not threaded and you need to use locknuts then you can get Areotight nuts from modelfixings.
      http://www.modelfixings.co.uk/specia...tm#Aero%20nuts
      Member of Mk Heli Club
        hi there
        i use 3mm split washers and standard nut's you can get them from local engineers supplies for peanut's,
        and have not had a problem
        mark
        MARK
        LOGO 500 V-BAR v5.2
        GAUI X4ii
        PROTOS 500
        MINI PROTOS 6S (stretched )
        GAUI X3. 6S
        JR DSX12
        14SG S-BUS
        proud owner of 2 x EGS
        www.bmmfc.com
          I just use Nylocs, after the first flight, tighten them up and all is good, the nyloc nylon doesnt last but the tightening under expansion does and they then dont come loose.
          Regards,
          Jason
            Thanks for your answers folks. That'll be the treadlock getting cleaned off then. I already have the lockwashers, just went ahead & threadlocked em anyway....
            Thanks again
            Mick
              You have the right idea, its completely pointless using threadlock on things that get hot.
              Current kit
              Evo 50
              T-rex 500FG night setup.
              T-rex 700N pro
              T-rex 450 pro
              10CP
              Frankenstarter (dynatron)
                I use heat proof engine locktite on mine and a smear of epoxy to join the two surfaces.
                must disagree about loctite on hot parts being pointless mine is rated to 300degrees
                  Ok, normal locktite then....
                  Current kit
                  Evo 50
                  T-rex 700N pro
                  T-rex 450 pro
                  10CP
