ESC on Belt CP
  • ESC on Belt CP
    Has anyone else had this problem? Had my belt CP for about 3 weeks. Just practising tail in hover with reasonable success when suddenly there is an explosion and she drops to the ground in flames. Quickly put out the fire which was on the ESC.......... toasted! Fortunately the only other damage was a broken skid strut. That esc must have been faulty.
    Yip i think you'll find there not the best ESC's and its a very common problem. You either get a good one or you dont with them ESC's. Even a good one though, well its not really good is it? Built as a cheaply as possible so you cant really expect anything else to be honest mate. Sad but true unfortunately. Just dont waste your money on another one, get an Align or Ace one instead or even a Flighttech Synergy. All reasonably cheap and will do the job 10 times better. I wouldnt bother putting anything more expensive then them in it though.
    Lee
    Lee
    www.raptoruas.co.uk
    www.lee.rcha-uk.com
    www.gensace.de
      say no more! great advice. definatley dont replace with the same.
      hovering and gentle flight seems to overheat them more that running them flat out! i think its due to the way they work. instead of reducing the voltage to slow the motor they pulse it, so in effect the slower and more gentle you are the harder they work and the hotter they will get!!( perhaps ashley or somebody more technical than me can explain it better??)
        the same thing happened to my belt cp esc the magic smoke escaped and it stopped working. it is a 25 amp speed controller if you didn't know so make sure you buy one of same or higher ampage to avoid and problems
          All the ones i mentioned above are 35 - 40 amp. They will run much cooler simple as that.
          What Ron (Boggy) says is spot on and what you need to do is run the motor at 100% flatline throttle curve. It keeps motor/ESC and battery cooler. You do that by finding a motor pinion that will give you the headspeed you need at 100% flat throttle curve. This is probably why the Esky one has went up in smoke to be honest. Im guessing here but if it hasnt just died as it was faulty or crap quality then theres a high chance it probably overheated which resulted in killing it. Are you using the stock Esky TX?
          Lee
          Lee
          www.raptoruas.co.uk
          www.lee.rcha-uk.com
          www.gensace.de
            ESKY ESC problems
            Hi
            I see various replaement ESC's suggested in this thread, and would like to add one more to the selection list.
            I had the dreaded zero to flat out rotor spin up with my new belt-cp and the standard TX and ESC which ripped my main gear to bits in no time flat. I purchase the Sonix 30A with BEC, set it to startup "super soft and it is a real dream. It has transformed by flying of the Belt for sure...
            Just a thought while you review the options.
            Trex 500 in Hughes 500D fuz
            Trex 450 with 5 blade head and 4 blade tail in Hughes 500E fuz + Align 3G
            CopterX 450 SE V2 - great machine..
            HKH500, Tarot 450 Pro
            F450 Quad with NAZA controller & on board FPV with GoPro
            Hero HD camera & now a shiny new NAZA GPS upgrade !!!!
            HELP ME TO HELP OTHER PILOTS - VISIT:
            http://www.chopperaddict.co.uk
            to find out how you can help...
            Thanks...
