Replacing tail drive on Belt CP
  • Replacing tail drive on Belt CP
    Hi
    Following an accident I need to replace the tail drive cog and shaft on my Belt CP can anyone tell me how to do it
    Regards
    Keith
    hi do you meen the gear at the front that runs of the main gear or the one on the end of the boom that the tail rotor is on
    Citizen: 280
      Tail drive
      The one at the front that runs off the main drive the cog goes on the main drive and the top drives the belt
      keith
        If I remember correctly, you just remove the screws in the frame around that area, prise it open and replace the whole shaft/ gear assembly. I think you need to remove an awful lot of screws to get it to open easily.
        Neil H: Certified compatible.
          Many thanks for that
          Kind Regards
          Keith
