Tail rota !!!
  • Tail rota !!!
    I am almost their with my Twister, thanks for the help with rebuilding the thing over and over again ops:
    My next questions is:
    I have to put a lot stick !!! (Right) to stop my Twister going constantly clockwise. Sorry if I'm not talking proper Helli ops:
    How can I reduce the amout of adjustment required, as the adjustment thing is nearly all the way over to the right and it need even more on the control stick !!!!
    Hellies are new to me at the moment and I'm trying to pick up the lingo :roll:
    to stop it going clockwise (viewed from above, nose to the right) you should be putting left stick in to make the nose go to the left.
    not familure with the twister but normally there is a mixer board, on the board there is an adjustment for "tail offset" this does the same job as revolution mixing.
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
      Is that the electronic box thing at the front with two pots !!!
        According to the manual, http://www.jperkinsdistribution.co.u...s/6600025a.pdf
        there is adjustment for gyro gain and mix gain. It sounds like you might need to adjust the mix gain to stop your heli rotating all time however only by flying it will you be able to determine the exact setting of Tx rudder trim, gyro gain and mix gain.
        Futaba 9CP & 10CG
          Thank you for the help
          I,m off to give it a go ! :lol:
            If its not that it could be 2 things that I found with fixed pitch electrics, Firstly the fixed pitch Tail Blade slowly loose's its pitch and doesn't work as well, and secondly the tail motor loose's its ouput before it fail's, so if you can't sort it with the setup, try replacing these.
            And a DX8 too
