the right gyro for a raptor 60
  • the right gyro for a raptor 60
    Hi there,
    i have a Raptor 60 and need to buy a gyro for it i have been looking at the GY401 could you tell me is this the right gyro for a 60 if not what should i go for?
    thanks for you help
    What goes up must come down
    Mark
    I think it will all depend on what you are wanting from a gyro. A 401 should suit you ok if you are a sport flyer and getting into light 3D. I fly a 401 on a Raptor 50, and it works just fine with my style of flying (sportish)
    The other option which seems to be extremely good is the spartan. Lots of the extreme 3D flyers at the club I fly at use the Spartan and its rock solid in agressive 3D.
    I am sure others will pipe up during the day and give you sound advice on what would be good for you.
    Rgds
    Aidi
    700N 700E 550E
      401 shud be fine for a 60 size heli ....it also depends what sort of flying style ya do .. 401 will take ya all the way upto mild 3d so i am told
      Knight 3D
        Used to fly a 401 on my Raptor 60- once I got past the stage of sport flying- got into backward flight and 3d-stll learning that I'am afraid!!- found tail would sometimes let go,,, since upgraded to a 601 setup,,,,,, waaay better- really all depends on your level and style of flying.
        Sab Goblin 570
        Sab Goblin 500
        500E Pro dfc
        450 Pro dfc
        Blade 300X
        DX9
          601 or 611 or spartan no contaest imo
            a 401 with am s9254 servo will be fine, i fly my 600 with this set up and will hold the tail perfectly well, Let a hardcore 3d flyer have a crack with the super pro and he thought it was excellent for a 401, only thing i would say lets it down a little for the hard 3d flying is it is hard to get the gain perfectly correct, to get it to hold perfect on tail down drops you have to have it highish, but then can cause a little waggle when punching out.
            If you want to go all the way to hard 3d then an 611 set-up would be the better choice
            James
            Sponsored by
            Align-Trex.co.uk
            Optifuel/optipower
            MKS servotech
              Spartan 760 would be the better option but if your on a budget then go for the 401/9254 combo. Will tell you now that i cant seem to stop praising the spartan thesedays, its one bloody brilliant gyro and rock solid feel to it. I highly recommend one to anyone.
              Lee
              Lee
              www.raptoruas.co.uk
              www.lee.rcha-uk.com
              www.gensace.de
                a spartan with a 9254 is just as good as a 611 combo and nearly half the price
                spartan £125 9254 £50 611 combo £279
                  Well I just have to say thank you for all the reply's I am blown away that so many of you have replied
                  I am more of a sports flyer at the moment mainly I think because I haven't crashed & repaired it yet so the the idear of having to repair it still seems a little scary???? So is starting to held me back!
                  Once again thank you for all the help
                  It looks like the weather will be turning good next week HAPPY DAYS
                  Mark
                    The other thing I would add about the 401 is that it is very easy to setup and pretty much works straight away without much tweaking.
                    Some of the CSM gyros are quite good as well but they are not any less expensive and since the 401 is very popular in the US as well there is a ton of info on forums about it (not that you'll really need to scour forums anyway because with the 401 most of the time you can pretty much just stick the thing on and connect the wires and off you go)
                      Id say the same thing about the Spartan to be honest. A sinch to set up and the stock gyro settings work a treat.
                      Lee
                      Lee
                      www.raptoruas.co.uk
                      www.lee.rcha-uk.com
                      www.gensace.de
                        I'd like to put in another recommendation for the Spartan.
                        You don't have to be an experienced 3D pilot to reap the benefits of this gyro. It really holds rock solid whatever your doing and is precise. Its only about £40 more than the 401 and will quite easily grow with any experience you may gain. The same can't be said of the 401. So overall I think its a sound investment.
                        The Spartan also holds its resale value incredibly well should you change for whatever reason.
                        Ant
