Found this setup advice on another site.
Makes sense, and has helped get my CX2 into a stable hover, which it wasn't doing out of the box.
Quote - "
1. center the gain pot setting
2. center all trims tabs
3. (if programmable radio no sub trim)
4. using the throttle trim tab.. push it forward until you hear the motors start to hum and then one blade starts turning.. adjust the motor potential setting to get both turning the same at that low throttle. (remembering to unplug the battery, adjust & then reconnect)
5. throttle up to a hover and adjust the gain for left or right drift..
6. if that doesn't work.. repeat only overcompensate for the drift by adjusting the motor potential to start that motor first. all else fails.. the motor is bad."
My CX2 needed full clockwise on the potential to get both motors to start at the same time.
From there, it was straight into the "stable" hover that i'd heard so much about, but had never seen.
Just thought i'd pass this on to anyone else that is struggling with the usual clockwise yaw that seems to be part of the ownership experience.
Put two batteries through since the change, and it's MUCH better.
Quote - "
the bottom blades should start before the top set and run slightly faster! if they start together you will get a clockwise drift.
