If it isnt broken.....
    Originally posted by jboweruk View Post
    Maybe the sub trim on the throttle isn't the same for everyone, sorry mate. I had to do -100% or my throttle wouldn't close. That's why I put it up as that. Can't understand why she would fly like a pig though.
    OW, I see you read it as swash made no difference, it's pitch that makes no diff. its not attached mate. Swash has to be 90 @ 1 servo.
    Sorry, sounds like your probs are partly my fault, not clear enough. Sorry mate.
    Don't be daft, I was grateful for your help and time.
    I think with the sub trim, one way or another there's not one same make of heli out there the same.
    I found minus 30 took hold of the throttle situ' but it was dead weak on the cyclic, after that everything went to shit even the battery's, beats the hell out of me, and it did quite literately.
    I took the 450 out for some relaxing tail in, while sitting on my patio door, and then it got gusty, I landed and called it a day.
    I adjusted the pot clockwise as it was turning to the left, now that's whacked the batt power out again f#cking thing.
    sigpicWayne AKA OB1
    Plus 3 Eddie Gold Stars, yay!
      wayne just bind it to a new model plane memory slot and tweak the reverse menu as required! no setup neccassary
      Your kidding that easy! jeez, thanks bud', one thing Ron, with the power prob's, any ideas on that, as before the first bind all the batts were perfect, well everything was.
      Thanks mate.
      PS, doe's it matter what way the bind plug goes in?
      sigpicWayne AKA OB1
        Ah, but then it's a plane. It only takes a few minutes to get it right as a heli. And then you have all the correct trims. If I hadn't bound my Skylift as a heli it would never have flown Ron....
        getting that skylift to work i dont doubt for a second john that was a feat of endurance mate
        as for the cx its only the picture that is different all trims etc work as normal. my theory is simple is best!
          OK things still aren't great, the nose rudder is drifting bad to the left OK I need to pot adjust that, I've just ran three batts through her, remembering I was getting 10-12 good minutes before the dx6i binding
          The e-flite managed just under 3 mins before the off point and the electrolites done better but not there usual great with one just over 8 minutes the second just over 5 mins.
          When I thought I'd cracked it I made a minute pot adjustment then the batt performance dropped like a rock, saying that it still wasn't up to par since you know what.
          Would a bad trip cause this level of batt performance, or is it possibly somethings gone tits up in the 3in1 while trying to get it to work with that.
          As before this little flyer worked fantastically with excellent flight durations, general flying, & within five minutes changing over the TX it's all gone to pot.
          Situation: two different types of battery's being charged in 4 different charges or all batts one after another in the Blades charger now give around 50% less flight time than it used to, with trimming probs like I've never had before.
          So its not the chargers as the Trex batts charge just fine.
          Someone here must have an idea why this has happened?
          I doesn't make sense at all!
          sigpicWayne AKA OB1
            Don't fiddle with the pot, use sub trim on the rudder to lose the yaw drift, it's quicker and easier.
            I can't see why the tx would affect it at all mate, it's totally seperate. You say it crashed after you changed over? Could something in there be binding?
            John
            sigpic Proud holder of an Eddie Gold Star.
            Too many hobbies, not enough hours in a day.
              Thanks John, well I checked everything over and all seemed ship shape, no binding of the cogs, no bent shafts, all as it should be.
              Yes I do the same, during a batt flight as she burns up the juice the torque changes and rudder trim always has to be add so to keep them true.
              But this is beyond simple trim, I'm as confused as yourself, it doesn't make sense, four batts all with the same prob, all charged on different chargers and on each charger the same results seem to happen.
              The Electrolites are far superior to the e-flite batts and have more balls, but eight minutes even for them is disappointing.
              I can recommend them more mate, buy them for your Contras the power surge these puppy's have will blow your mind, they will almost super charge your CX2, and for £6 each!
              sigpicWayne AKA OB1
                That's what I mean mate, I always use sub-trim instead of the pot now, saves knocking the canopy off. have you tried Ron's suggestion to use it as acro instead of heli? See if that makes any difference. But I can't understand why your batts are taking such a hammering. Are they hotter than usual when they come off?
                John
                  Originally posted by cambs flyer View Post
                  I known it's a big order but could you when time alloys give me your 450 settings you have with your DX6i then I can compare them with the DX6's and program them in, but only if you get the time.
                  No probs mate.
                  I'll print them out and pop them in with your bits.
                  Sorry they haven't been sent yet but this week has been busy busy busy etc
                  Mark
                  sigpicx2
                  Airskipper 50 - For sale
                    Please Mark, don't you dare apologise you've done me proud with our little agreement via PM's
                    Thank you very much indeed bud'.
                    sigpicWayne AKA OB1
                    • #25
                      So it's confirmed, no one here can shed any light as to why this is happening.
                      Then I guess it's back to the shop time then.
                      sigpicWayne AKA OB1
                      • #26
                        That's why I ask if the batts are hotter than normal... If so it would indicate more power being drawn. What I can't work out is how it's possible for the tx to affect it.
                        John
                        • #27
                          there quite warm after the short flights I'm getting now almost like there had the usual flight times.
                          I think something gone belly up in the 3in1.
                          sigpicWayne AKA OB1
                          • #28
                            Ow, they're about 35 quid too. Hope you get it sorted mate. The CX2 is a lovely heli and as I said, on my DX6i even better.
                            John
                            • #29
                              Cheers for that John.
                              As of now it's winging it's way to Rod at Elite, as he said he'd have a look for me.
                              Top bloke!
                              sigpicWayne AKA OB1
                              • #30
                                If it's anything like last time he'll sort it mate.
                                John
