Can I ues these setting for my align 250
  • Can I ues these setting for my align 250
    Hi again.
    I found this review/settings for the 250. Can I put these setting in my transmitter?
    I know typically that a 250 is not seen as a beginner's heli as it can be very twitchy and fast but given that it doesn't need a load of space to fly, is cheap to repair after crashing ops: and an all round top little heli, I thought I'd share my TX settings (DX7) that can tame this fiery little beast into a very manageable CP beginner's heli, hopefully with a bit of an explanation of each setting I used.
    Disclaimer here – I’m very much a newb but I never really found all this info in one place so hopefully it’ll help someone, but to you expert pilots this is probably sucking eggs territory! Of course the principles can be used on any heli, I just did a lot of research and applied it to my 250 as it’s a much more feisty heli.
    First I will assume that you have centred the servos and set servo direction & interaction and levelled the swashplate throughout its range. Also that you know how to use a pitch gauge and take pitch measurements. I recommend the eBooks from rchelicopterfun.com if you need good setup guides.
    Throttle Curve (Normal) - 0-80-80-80-80. The soft start on the ESC is really good and a flat throttle curve helps with stability, as the head speed is constant.
    Swash Mix - Aileron: 50%, Elevator: 50%, Pitch: 40% I used Finless & Jasmine's set up guides from HeliFreak and took the suggested 50-50-50 as a starting point but after levelling the swashplate throughout the travel I found I was getting +/-13 degrees collective pitch which is quite high so reduced the Pitch mix to 40% which gave me -10-0-10 degrees.
    Pitch Curve - With zero pitch at midstick, I find a good beginner's pitch curve is about -2 to +10 degrees, just a bit of negative pitch at low stick so that if the throttle is killed, as a beginner will often do, it won't drive the heli into the ground! To get the -2 to +10 degree range my TX curve was 40-45-50-75-100
    OK, nothing radical here so far that you haven't seen in a thousand other posts.... Now I found a lot of posts now move straight on to setting 25% expo as a beginner's tool to reduce sensitivity around mid stick. Not that I'm against expo but before going there I'd suggest looking at cyclic pitch. Every site mentions setting collective pitch but not that many talk about cyclic pitch - basically how many degrees the swashplate tilts when you apply full positive/negative elevator/aileron. If you start with a standard swashmix of 60-60-60 the chances are you will get about 12 degrees of cyclic travel. This is a HUGE amount - unless you are a 3D stick banger it's unlikely you will ever need this much travel - 6-7 degrees is all you normally need as a beginner or for sport flying. With my 50-50-40 swashmix above I was getting about 9 degrees.
    Now if you have a high amount of swashplate travel and use expo to tame things down around centre stick it works well until you (as a beginner) get into trouble and over compensate your stick movements and all of a sudden those 12 degrees in the opposite direction kick in very quickly because of that expo (travel is the same but the rate it's applied proportional to stick movement is different) and the heli piles sideways in to the ground. I speak from bitter experience here
    So what’s the solution? Dual Rate. I found lots of sites mention DR but without much explanation as to how it works, except it reduces the amount of servo throw/travel but without relating it numerically to cyclic pitch. If you consider the 9 degrees of swashplate tilt I got with my 50-50-40 swashmix and then think of the maximum cyclic pitch you’d need for basic flying, probably about 6 degrees, you can see that if you set your dual rates to 66% that would limit the maximum amount of cyclic pitch to 6 degrees (6 being 66% of 9)
    After you set DR you can add expo if you wish – I set my dual rates to 70% with 10% expo on Aileron and Elevator and 65% with no expo for the Rudder which is nice and stable and smooth for me but your preferences may vary!
    Hopefully that will result in a nice stable, tame 250 for you!
    I'm sure those settings can work but personally i'd not recommend normal mode and I've use a 'v' shape curve to avoid bogging under load... But there is more than way to skin the cat, those setting you list should work well enough to get you into the air.
    You really need to tell us what the setup of the heli is.. Is it flybar or flybarless. If the later what FBL controller?
      Its a flybar version. I've set the heli up to the manual
        So what's the v? Sorry I'm new to all this lol
          A V curve is, as the name suggests, shaped like a shallow 'V'. The idea is to apply more throttle as the pitch increases to prevent the motor 'bogging down' under load.
          So for your suggested 'beginner' pitch curve you would match it with a V curve that looked something like: 75-75-90.
          For a more 3D/aerobatic orientated pitch curve you would match it with a throttle curve that looked something like 100-80-100
          And you would start and stop the motor using the 'Throttle Hold' switch.
            So what shall I put for L 1 2 3 H?
              You dont really need all those flight modes when you are learning. One mode to fly in plus throttle hold ('H') will be enough.
              For throttle hold use the same pitch curve as your flying mode, but make the throttle curve 0-0-0. Throttle hold should be activated off a seperate switch from your flight mode switch.
                I've got throttle hold the same. It's a flysky tx and it's got L-1-2-3-H for pitch curve and the same for throttle curve. It's just filling in the gaps lol.
                  ok, I'm not familiar with the Flysky Tx.
                  The L-1-2-3-H must be the five points of the curve....
                  For your pitch curve based on settings you mentioned in your previous post:
                  L=40
                  1=45
                  2=50
                  3=75
                  H=100
                  And for throttle curve based on my suggestion:
                  L=75
                  1=75
                  2=75
                  3=88
                  H=100
                    So the heli will spool up on 75% ? So have throttle hold on first lol thank you for your help
                      Yes, that's right, you just release throttle hold and the heli spools up. You have to have 'soft start' enabled but that should be set by default on any ESC fitted to a heli.
                        should H not be minus 100
                        Trex 550e dfc :-)
                        t-rex 450s x2 /Raptor 50
                        kyosho spree small plank
                        bogey combat plank x2 woop
                        http://www.cuffleymfc.co.uk
                          When throttle holds off have throttle mid stick zero pitch.
                          • Flickr Through My Pictures.
                            If the throttle starts at 75% when the heli spools up, will it take off? I'm confused.
                            Can someone please contact me and go over the transmitter setting over the phone? 07833070757
                              I'll get me TX & read you of my setup.
