repair
  • repair
    Hello all
    Just repaired blade 450x new set of blades and main gears.Check servo all ok.So the question is swash arms have been taking of to check servos all ok.
    To put the sero arms on do I need to go through AR7200 beastx set up or wait to the heli sets it self up then just put them on with the swash level and blades level at mid stick.
    Thanks in advanced
    Dean
    Blade 200SRX
    Blade 230 S
    Trex 450l dominator
    Trex 500 Pro
    450 Forza
    RJX Extreme 50N
    1500 Varioo scale Jet ranger (scorpion motor)
    PL6 with coolice PSU
    neXt sim
    DX9
    for time it take just set up fresh.
    Santander Factory Team
    Proud wearer of 5 x EGS
      I would start again with the servo arms reset at 90 degrees (get as close as you can to 90 on the splines and then trim through BeastX). Then go through swash levelling procedure etc to complete. If your servos were originally set to 90 degrees and the swash was level, it shouldn't need much adjustment on the links.
      Blade mCPX - sold
      Spektrum DX8 - for everything
      ne
        Personally if all I'd done was changed blades and main gear then I'd just pop the arms back on to be level at mid stick. If you haven't opened up the servo to change gears and haven't changed or adjusted any linkages then the setup should be still fine. Each spline makes a big change in arm position so you would have to try pretty hard to re-fit the arms on the wrong splines.
        Of course it does no harm to go through the setup again if you wanted to but it shouldn't really be necessary.
          Yes, that's true Grumpy. It should be obvious what position they need to be in.
          Blade mCPX - sold
          ne
