blade 230S
  • blade 230S
    Hello 230s owners
    Is any body having problems with the 230s in the wind mine seems a bit jumpy, shaky in the windy.
    Thanks in advance
    Dean
    Blade 200SRX
    Blade 230 S
    Trex 450l dominator
    Trex 500 Pro
    450 Forza
    RJX Extreme 50N
    1500 Varioo scale Jet ranger (scorpion motor)
    PL6 with coolice PSU
    neXt sim
    DX9
    Small helicopters don't like wind.
      Hi Dean ,when in forward flight even 450's can jump up or down 10 feet in the wind , sounds normal to me , just another thing to fling into the heli mix , lol
      Goblin , 380 Carbon
      Oxy 4 - 360
      Oxy 4 - 325
      Oxy 3 - 250 , 3s
      Oxy 3 - 250 , 4s
      Oxy 3 - 280 , 3s
      Oxy 2 - 190
      Oxy 2 - 210
      Spektrum DX9
      Revolectrix PL6 & PL8
        Hi Dean,
        Check my PM,
        We know Normally, it does fly ok in the wind... If possible how is it with no wind? (I know thats a big ask in the UK)
        You said you had a mishap recently so, check through your gears for meshing & smooth operation, check main & tail blades for any nicks / damage, do a balance check of the main & tail blades. When in the hover check if the skids and / or the tail has any vibration, if so then you need to find the cause.
        Vibration will upset the FBL unit.
        When power up before flight, ensure heli is on level ground and that the wind is not moving the heli whilst it is initialising.
        I am back soon so we can sort it.
        Brain Goblin 380. Brain Goblin 500 sport. Spirit Trex550e DFC. (BeastX Trex450Pro, BeastX Trex550e DFC... in Thailand)
        Brain Oxy 2, Nano CP X BL.
        neXt-Heli, DX9. DX6 G2. PL8 + Coolice 2400W PSU.
          Originally posted by Dean airwolf View Post
          Hello 230s owners
          Thanks in advance
          Dean
          I wouldn't say my 230S shakes in the wind. It does "bounce" around a bit if it is gusty.
          It also sometimes "porpoises"/tail bobs when it is flying fast(ish) into the wind -- I think that that is probably a gain issue that I need to sort out.
            Hi Dean, do you notice a difference in tail behaviour in each flight mode, or just one in particular? Mine tends to behave better in IU2 - maybe the increased head speed/torque is more in line with the FBL's sweet spot in terms of default gain/control sensitivity, I don't know) I think the stock gain settings mean that an occasional porpoise or sudden collective change wobble (increased motor loading) happens due to the limitations of the FBL and DD tail motor, I think....I've seen the same on mine sometimes. Wind tends to create similar behaviour. I don't want to start messing with gain settings just yet, I'm too early in my learning curve and I think the DXe is limited in what can be done anyway - I guess if you have a decent Tx (I don't....yet) then you could try changing settings?
