Can I ask lots of stupid questions and hopefully get some not so stupid answers please?
The Blade Nano CP-S manual says:
Does the nano actually "know" what F-Mode is? IE: I set up switch B for the 3 modes, does the circuit on the heli know that it wants stability, agility or 3D modes? Or is it purely through the setup of the throttle and pitch curves?
From that manual, it says to set up mixing, GER->GER, rates at 100%, offset 20% on the bind button. The images on the DX6 look like this though:
So is that right? Obviously I need to set the switch to I rather than inhibit. What do 1, 2 and 3 relate to?
When I tried pushing the button the LED on the nano went red/blue together and I had no controls at all, couldn't get it back to blue either without unplugging. Hence setting it to inhibit.
F-Mode 1 and 2, I assume I need to put hold on, set throttle to the middle, flick switch B to 1 or 2, then turn off hold?
This will set throttle on permanently, but with no pitch - so 3D effectively. Is that how helis are supposed to work? Is there no way to ramp up the throttle to midpoint? I'm scared to do it through fear of fire and death.
Trim. I currently have elevator at +24 and aileron at -4. The +24 doesn't seem right to me, is that a normal kind of value to have to use?
It may be because I'm only flying in the kitchen at the moment, it's narrow so there may be some strange windage and ground effect stuff going on?
At least I have managed to do some flying, it drops really quickly compared to the NanoQX, which surprised me, I hope that's a CP heli thing and not my settings.
