I installed a new Aileron servo this morning as I'd broken the teeth trying to adjust trims in the wind on Tuesday, blade had a slight off power hit teeth broken, no other damage.
So I installed it, sat her on a stall adjusted the trims so the Swash was level, moved the throttle stick half up and down, went to the field adjusted the trims a little after a few small hovers then perfection, she was hovering and moving as sweat as a cherry.
As she moved a little away from me the motor for a split second lost power, like a burp, so I pushed the DX6 Ariel to the up position, but I still had these split second power glitches.
Until I had her a bit further away and was banking slightly and all power was lost, luckily she landed on a very soft grassy area, I've bust a small plastic arm in the head but no other visible damage, all the servos work fine
But the banana leads that go from the ESC to the motor were out of each other a little with the black lead almost out over half way, I usually have them tapped together but didn't today, could this have cause it? or could they have been nudged when she landed hard, my gut feeling thinks it was the loose leads, as I've had her much further away from me before and shes been fine.
I'm really pee'd off I was doing snake like turns forward, I even Had her hovering side ways to me, fairly close and she was as good as gold, but about twenty feet away the link was lost and luckily she wasn't high and it was on soft grass as I say, but any ideas chaps?
It's a bastard being brought down when it wasn't pilot error, at least if it was I could be kicking myself right now.
Thanks.
Thanks.
