Originally posted by feathering
View Post
Budget TX
That made it a no-brainer for me.Originally posted by myxiplx View PostAlso, Blade micros all bind to Spektrum (some even include spektrum radio settings in the manual), so you've a huge choice of small models to learn on that you can just pick up and fly.
-SAB Goblin 380 KSE - latest love thang
Blade mCPX - sold
Spektrum DX8 - for everything
neXt sim - the sim I started out with
None of that lot would add any value for me, but I guess we all have different needs. I did hold the new DX6 in my hands when I was comparing with the DX8 and I didn't think there was much in it at all. The black finish on the newer models looks a bit better, but not a big deal at all. If I was buying new today I would probably go for the DX7 at £200, but not as an upgrade from my DX8. Oh hang on, the new DX7 wouldn't bind to my mCPX so that would have ****ed me off from the start!Originally posted by Paul_basildon_helis View PostThe reason I went from the Dx8 to the new Dx7 was because I was missing out.
The new models look and feel nicer
The software is much simpler and easer to make adjustments.
It speaks to me so I don't have to look
I have can buddy up with a Dx6/7/9 wirelessly.
I can swap models with the above models via sd card.without needing to convert them on my pc, this was a pain with a couple of second hand models I bought bnf.
The biggest fault with the Dx7s and the Dx8 for me was incompatibility with other tx'sSAB Goblin 380 KSE - latest love thang
Blade mCPX - sold
yes, I misunderstood. Thank you for the clarificationOriginally posted by fishfiend View PostI think you misunderstood me, I have separate set ups which include a full devo rx with a full sized vbar, along with 2 other models, one of which has an ar7200 with dsmx sats and another with a robird g31 fbl controller and single dsmx sat. You can only work with one protocol at a time, and the devo line doesn't require satellites, but you'll need to run separate leads for each servo. Hope this helps.
The dx7 g2 doesn't bind to the mcpx because the latter is dsm2? Is that the case for the mcpx bl as well?Originally posted by Peteski View PostNone of that lot would add any value for me, but I guess we all have different needs. I did hold the new DX6 in my hands when I was comparing with the DX8 and I didn't think there was much in it at all. The black finish on the newer models looks a bit better, but not a big deal at all. If I was buying new today I would probably go for the DX7 at £200, but not as an upgrade from my DX8. Oh hang on, the new DX7 wouldn't bind to my mCPX so that would have ****ed me off from the start!
This is a good point. Although I very much enjoy programming (including c++ which I think is used for opentx ?) there is much to learn about helicopters but only so much available time. Starting with the easiest options may help.Originally posted by myxiplx View PostA lot of it depends on how comfortable you are fiddling, working things out on your own, or reading forums online. If you're happy to tinker the Devo 10 w deviation or Taranis would be great choices. I'd recommend the Taranis out of those two, while I love my Devo 10, the Taranis looks to be much higher quality, and the OpenTX firmware has a much more active community working on it.
However for a beginner it's hard to fault Spektrum, and there are plenty of good second hand Spektrum radios out there. While not as capable, there are a lot of advantages for a beginner with a big one being a lower learning curve on the radio, everybody knows Spektrum, so it's easy to get help and advice. There's a ton to learn with RC Helicopters and getting a radio everybody else knows definitely helps.
that's right, but don't know about the BL. As it's a newer model I suspect it is dsmx which should be okay. You should double check if you are going down that route.Originally posted by feathering View PostThe dx7 g2 doesn't bind to the mcpx because the latter is dsm2? Is that the case for the mcpx bl as well?SAB Goblin 380 KSE - latest love thang
Blade mCPX - sold
