Trex align 450 clone thingy batteries
  • Trex align 450 clone thingy batteries
    I have got a trex 450 clone that has been rebuilt using align stuff so is far less of a clone than it started. I have one battery for it which is a overlander 2200mah 11.,1v 3s. I need to have more than one battery but don't know where to get more on a budget from. I have a T shaped plug. Please can you guide me through where and what to get for a good deal. Links direct to the item would be ideal as websites bamboozle you with choices in their incomprehensible ranges.
    I have a balance charger
    Bryan
    Checkout Hobbyking have a look at the 3s 2200mah turnigy batts they will be fine and very good price
    Trex 500l Dominator
    Trex 450l Dominator
    Mcpx bl
    Pheonix sim
    dx8
      They look like a different connector, can you point me to the right one please.
      Bryan
        U may have to solder a matching connector to yr esc sounds like u might have a deans connector on yrs, u need an xt60 connector if u get the turnigy 3s batts
        Trex 500l Dominator
        Trex 450l Dominator
        Mcpx bl
        Pheonix sim
        dx8
          These HK 25C packs should be okay for you:
          Turnigy 2200mAh 3S 25C Lipo Pack (UK Warehouse)
          But if you have the Deans type plug on the ESC and don't fancy soldering then you can get adapters to suit:
          http://www.hobbyking.com/hobbyking/store/__61689__T_Connector_to_XT60_Battery_Adapter_Lead_ 2pc_.html
            or a convertion lead
            walkera 4#3a full brushless
            walkera 4g3 soon to be brushless
              Connectors is a subject that you will have to come to terms with in this (or any rc) hobby.
              If you can't already do so, learn to solder.
              Decide which connectors you want for your heli, then, if necessary, change the connectors when you buy a new battery.
              I settled on XT60 connectors for my 450 mainly because the Turnigy 3s 2200 batteries have them as standard
              My advice, which you don't have to follow of course, is to buy a few XT60 connectors if and when you buy the Turnigy batteries. Solder a male on to your charger lead and to the esc on the heli. Put a female on your existing battery.
              If you are still learning the 20c Turnigy packs will be fine. I got about 90 cycles each out of mine before they started to deteriorate significantly. They are by far the best value, in my opinion.
              Edit. The last three posts were made while I was typing this!
                Thank you all 2 batteries now ordered, just some connectors to sort now.
                Bryan
