Can anyone give an idiot guide to bind blade srx to original transmitter. Thanks
Bind heli
Tags: None
From page 8 of the manual, if it helps.
LP6DSM Binding Procedure
1. Disconnect the flight battery from the helicopter.
2. Lower the throttle stick to the lowest position. Set the throttle trim to the highest position. Set all other trims to the center position.
3. Power off the transmitter.
4. Install the bind plug in the receiver BIND/PROG port.
5. Connect the flight battery to the ESC. The receiver LED flashes, indicating it is in bind mode.
6. When the LED is flashing, press and hold the Bind Switch while powering on the transmitter.
7. The transmitter will beep and the LED will blink. Release the Bind Switch when the transmitter stops beeping.
8. The helicopter is bound when the LED on the receiver control unit is solid.
9. Disconnect the flight battery and power the transmitter off.
thanks much appreciated,Originally posted by SGD View PostFrom page 8 of the manual, if it helps.
will pop along rich, just cleared it with the governorOriginally posted by Rich23 View PostHey
Bring it along to the Ashford indoor this evening and we will help you sort it out.
Rich
