Hi everyone,
First post and already have a problem!
I bought a Belt CP with simulator cable and training gear, the parcel arrived and inside was a note saying "charge and check" the lipo battery on the day of receipt incase of problems.
I read the manual then charged the battery and to give it a quick check I set the TX as instructed and loosly connected the battery to the heli. The heli completed its check and beeped several times, I then slightly raised the throttle, the blades started to spin with a slight swishing noise.
I returned the throttle to the rest position and started to disconnect the battery this proved to be very dificault ,so I moved the TX out of the way to get better access, as I pick up the TX I knocked the long switch against the floor (it's labelled Idel/inverted flight) the blades jumped into life as the motor seemed to go to full power, the whole heli spun round and hit the box then jumped in the air throwing the battery 3 meters accross the room then hit me and the floor making a loud clicking noise.
One I had determined that my arm was still attached to my body and the pain had subsided I retrived the battery and checked the heli for damage, I could not see anything obvious. I strapped the battery in and moved the switch back to its correct position. I connected the battery then raised the throttle a bit, the blades spun as before but the heli shakes now, I increased the throttle to see if it settels but it just gets worse. I removed the battery and rechecked the heli, on closser inspection I can see the main gear has slightly chewed teeth in four places equally spred out.
Is this likely to be the cause of the shakes would the main shaft be bent. also what is a feathering spindle?
