HBFP throttle postion at hover
  • HBFP throttle postion at hover
    Hello,
    At what % throttle postion (50% = center), does your stock HBFP hover 3 feet from ground (no wind conditions) ?
    Please specify batterry type ? (2S 800mAh Lipo, ...)
    Thank You.
    Hi userrc,
    There is no answer to that one, as you will need small inputs to keep station, and if you have not managed to trim it out properly (almost impossible to start with!) you will always be overcontrolling.
    ....but basically the helicopter should lift off at somewhere around 60% - 65% throttle and thats as near as I can get to answering your question! (800maH LiPo will be broadly similar in performance to the stock 850maH NimH, but last quite abit longer)
    Hope this helps
    Phil
    Phil OB3
    Trex 450SE v2
    Walkera 4#3b
    DX6i
    Phoenix
    http://stratfordgliding.co.uk/
    ...and proud owner of THREE!
