Hi all,
I have taken the plunge (after some advice on this forum) and bought a RTF Trex 450SEv2 - supposedly already been test hoevered.
I have a Blade CX2 and a Honeybee CP2 (twitchy little bugger
, so I'm not a total, total 'noob' but the Trex is somewhat more complicated (and expensive!) than anything I've flown before.
I have a few questions before I attempt my 1st flight on this little beastie:-
Question 1: I'd like to check the pitch for myself, is the safest way to do this to disconnect the wire from chan. 3 of the receiver (receiver is Futaba 6ch - chan 3 is the throttle) - so I can push the throttle stick through the full range with no chance of the motor kicking in!
Question 2: The receiver is a 2.4Ghz Futaba R606FS with 2 fairlly short antennas - and the little leaflet explains these should be placed at 90 degrees to each other. Currently these are sort of hanging loose point back towards the tail (I'll try & post a pic if I can work it out!). So the question is...should I be securing these wires somehow to try & keep them roughly at 90 degrees? If so any suggestions to what and how ?
Question 3: I have a Futaba 6EX Tx - what setting should I have for the failsafe for the throttle? I would think this should really be set to 0% but the lowest it goes is 16%. Given that if the Rx looses contact with the Tx you are going to crash...surely you don't want the throttle still trying to sping the blades when you are in a heap on the ground?
Many (many) thanks in advance for your help/advice!
Jonathan
, so I'm not a total, total 'noob' but the Trex is somewhat more complicated (and expensive!) than anything I've flown before.I have a few questions before I attempt my 1st flight on this little beastie:-
Jonathan
