First Crash!
  • First Crash!
    After about ten flights with my 450 I got a little bit too clever and got a bit close to the deck with the model banked over.
    The result was the blades jabbing into the ground - I killed the throttle and once I knew it wasn't going to try doing the chicken dance I disconnected the battery and had a look. Nothing was hanging off broken so that was a good start.
    The boom had taken a little hit as it had been shoved in a bit letting the belt go slack. There was no damage to the tail but I gave it a good check over and got the tension right again.
    Going on what I have read I know that any time something stops the blades turning the main shaft and feathering spindle are at the top of the list of things that can bend. With the blades still off, I plugged the battery back in and got the head spinning at the lowest rpm - the main shaft was bent
    I got the head all off and took the feathering spindle out. It didn't look bent but I know it doesn't have to be visible to cause bad vibrations. I rolled it down a bit of photo frame glass and it was fine, phew. I used this opportunity to inspect all the ball links, swash and servos and they're all fine.
    I saw the main gear had some damage to a couple of teeth so I replaced it, £5.49 for three is a pretty fair price for spares
    I then inspected the blades, it was only the tips that caught the soil but I looked them over and gently flexed them to see if there were any cracks. I also had a good look at the mounting holes and roots and I couldn't see anything wrong there either.
    I had it flying before and the tracking seemed a little off, but I fiddled with the links and it seems okay now. The machine feels a bit twitchier but I guess that is a common feeling with a machine you've just repaired.
    I think I got off lightly there
    Nice one to have gone as long as you did without biting the dust.
    I have never had a crash that did not bend the feathering spindle, in fact after one stack that was the only thing I had to change!!
    The twitchiness is probably nerves after the last flight!
    good luck
    JAMIE,
    -Mini Titan e325-
    Sonix cnc head & tail rotor
    GY401 & HDS 577 servo
    HS65mg's
    CY radix blades
    scorpion hk2221-8 motor & 55a esc
    Spektrum DX7-goodbye glitches
      congrats on your first bump, sounds like almost exactly how I crashed my 450 - they're a sinch to repair but I'd recommend swapping the blades just for peace of mind - if one lets go the imbalance would rip the heli to bits, equally you've then got a nice little projectile swinging around at eye level.
      Andy
      sigpicX2
        I got a new set of blades but they're not Align ones, they are being a bit of a pig to balance but I will get them done.
        I was just hovering it again about 5 minutes ago when the yaw went a bit strange, it often happens if i land and take off again, the heading lock seems to lock too far over. Anyway I got a bit confused as I am only any good with nose in hovering so far and I went to pieces - landed in a small bush this time, again only a small way off the deck.
        No main shaft bending this time but I did snap the end off a mixing lever. One minor bump and I've opened the floodgates
          sorry to hear that - the confidence is the biggest hit after a bump, I reckion you could get away with doing no damage at all and still get the shakes afterwards.
          It's the reason I'm on 2.4Ghz - nice short aerial that doesn't amplify the shakes right up it's length. If you're not sure what I mean - check out a beginner plank flier on a buddy box and watch the tip of the aerial
          sigpicX2
            Yep I went with 2.4 as well, I love the short aerial. I got my nerve back just before this bump, I should learn to quit when I'm ahead :P
            This mixing lever might have been weakened by my original crash, I think I will replace both of them when I get new ones delivered.
