ark x400 probelms/help
  • ark x400 probelms/help
    hi there guys went out today for a secound time learning to fly, slowly upped the throttle probley was going to start to hover then pop, off came a tail rotor - it broke the bit that holds onto it via a ball joint to adjust pitch and it pull the thread out of the bit that hold the tail blades on- has anyone every had this problem before ? is there somthing that can be done to stop this happening again ?
    also spares does anyone know where i can get spares from ?
    rocky
    try hobby hanger rocky i doubt they have ark 400 spares but trex 450 bits are very similar and you may be able to make up a fix. (take it with you)
    when you reassemble it make sure to use loktite on all metal screws and ca glue on all screws into plastic
      yer ok, theres like a alu hub that the two rear blades screw onto, it must of pulled or even undone itsself, so loctite will use when get a repair,
      also belt tension am i right in saying able to touch the belts together but not the side walls is good ?
      rocky
        The original white plastic ARK x400 tale blades? One of them snapped off?
        These were prone to snapping I heard. Replace with the equivalent align trex450 part - straight swap.
        not sure exactly which bits you have are good - but if your tail case is good - just buy this:
        http://trexmad.com/newstore/index.ph...roducts_id=401
        This fits onto the ARK tail case and clips onto the ARK tail blade grips - but the slider is driven top and bottom so there is a lot less slop.
        info on alternative trex/x400 spares
          hi rocky,
          i had a tail blade fly off in mid flight the same as you. it only happend ones to me but it was very bizzare and did worry me. ( i havnt got it anymore)
          with spares,, there's no one in the UK i could find. i found these:
          http://www.microheli.com/mhshop/inde...8d1ee2e25fef6b
          they used to do a whole rage of spares but it looks like they only do a few upgrades now! ... fortunalty as boggy sais, nearly all parts are interchangable with trex450
            yes mate with firm presure the belt should just touch
              ahh just read moyesboy reply and the reason it didnt happen again is because i didnt replace them with the standard tail blades!
                x400 spares are all avaiable at www.trexmad.co.uk
                  ah thanks for the help guys, will check out local hobby shop see if they have the trex equil part if not will search the net.
                  Rocky
                    I have some Ark 400 bits if your interested??
                    Sponsored by Network Rail Wage's
