Hi,
Me again
! Still learning on the CX2 and very good fun it is too. However after a few more 'little' bumps I'm thinking that I will have to change the two main shafts as when you run it up to full speed the top of the head moves. My question is though how much indicates time for a new shaft? Looking at the design from new it's not exactly rock solid, there is a fair amount of play and flex.
As a quick survey when you run your CX2 up to full whack whilst holding on to it, how much distance does the top of the rotor head shaft move/flex through?
All help and comments greatly appreciated and used!
Mike
Me again
! Still learning on the CX2 and very good fun it is too. However after a few more 'little' bumps I'm thinking that I will have to change the two main shafts as when you run it up to full speed the top of the head moves. My question is though how much indicates time for a new shaft? Looking at the design from new it's not exactly rock solid, there is a fair amount of play and flex. As a quick survey when you run your CX2 up to full whack whilst holding on to it, how much distance does the top of the rotor head shaft move/flex through?
Mike
