Helicopter problems
  • Helicopter problems
    Hi guys, got a bit of a problem with my heli, because it was flying ok but now when I take of it does wide circles backwards and sometimes forwards and slowly gets lower to the ground could u please help
    P.s the helicopter is an indoor single prop heli.
    What model?
    If it's a cheap one chances are it's pooped. Battery sounds like it has had it.
    Happy Landings.
    David
    Raptor 50. OS50
    Mcpx
    Blade 130x
    Goblin 500
      Thanks for the advice but I only bought it a week ago and it also has two batterys
        Sorry forgot to mention the model it's a v911 micro indoor songle prop helicopter
          I had a fixed pitch micro heli from Heliguy.
          It was always breaking small linkages and the tail control had a mind all of its own.
          Have you tried adjusting the trims on the transmitter to get it back in control?
          If that does not help, you could try making very small adjustments on the linkages on the head, try a half turn and see what it does.
          They are so light that even a simple indoor change in air direction from a window had an affect.
          If its flying in circles forwards and backwards something could be loose in the head.
          Has it got a receiver with a combined gyro to help control the tail blades, that may be out.
          Have a look at the link below, it may help.
          I forgot to mention, if it is dropping slowly, I agree with above comment about the battery getting low, you may be running it to long?
          Apologies if above is already known to you, there are lots of far knowledgeable people on the forum than me, I could be talking poop!
          Mini Radio Single Propeller RC Helicopter Gyro V91 User Review - YouTube
          Good luck
          David
          _________________________________________________
          SEMAS Flying Club
            Thanks very helpfull
              Wide circles sounds like 'tbe' - toilet bowl effect. It generally affects fixed pitch single rotor helis with flybars.
              Dealing With Toilet Bowl Effect On Your Micro RC Helicopter
                Never heard of that, Thanks I will take a look as well.
                David
                SEMAS Flying Club
                  good heli but batterys not soor good av got one
